extract velocity gradient <user_getvar> error
3 Attachment(s)
Hello all,
I need help regarding the command user_getvar. I want to extract the velocity gradient using the command user_getvar. I wrote a fortran code to compute the velocity in the boundary layer. I compiled it using intel fortran compiler 14.0.3.202, it result 4 files including the .dll file which I need for ansys cfx but it gives me a warning, is it ok? "ifort: command line warning #10161: unrecognized source type 'winnt-amd64\\stand ard_wf.o'; object file assumed". If I run the simulation with the files resulted by the compiler, the cfx solver stops returning with the following error: Details of error:- ---------------- Error detected by routine MAKDIR CDRNAM = VEL /GRADIENT CRESLT = ILEG Current Directory : /FLOW/ALGORITHM/ZN1/SYSTEM/VARIABLES +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | In the fortran code, I want extract the velocity gradient like this: "CALL USER_GETVAR('Velocity.Gradient', CRESLT, pGRAD_V, CZ,DZ,IZ,LZ,RZ)" I attach the fortran code(standard_wf), the messages from compiler(compiler results), and the output file from solver(ansys error) Thanks in advance for support. |
I think you need to specify a velocity component, e.g.
CALL USER_GETVAR('Velocity u.Gradient', ................ CG |
I would try
'MyFluid.Velocity.Gradient' as per the documentation Quote:
Hello cfdgremlin, thanks for the quick reply.
I have tried your suggestion, but it didn't work I have the same error. |
1 Attachment(s)
Hello Opaque, thank you for the quick reply.
I called the user_getvar command like you recommended and the error it is gone. Now I have another error (I did the simulation in both single precision and double precision): +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | | Floating point exception: Invalid number | +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | Message: | | Stopped in routine FPX: C_FPX_HANDLER | | Can you help me? |
This is a FAQ: https://www.cfd-online.com/Wiki/Ansy...do_about_it.3F
I would check that your simulation runs OK without the custom wall function. |
Hello Glenn,
Thank you for reply, I followed the instructions from FAQ section and it seems that the errors is from the fortran code. I will post here when I will have a working code. Thank you all for the support. |
After I searched a little more and after some conversations with Ansys Support, it seems that I can not replace the scalable wall function with a custom wall function. I will move to Fluent, there I can implement a custom wall function. Thank you all for the support. |
