Can CFX model periodic heat transfer problem
Hi everyone, I come across this issue recently and have read many threads here already, still no clue.
Is it possible to model the periodic heat transfer problem in CFX? In fluent Help, there is a turtorial about modeling periodic heat transfer problem. But I cannot achieve it using CFX. I can successfully get the flow field, but not the temperature field. In summery, there are two problem. First, when I define the mass flow rate in the periodic interface, there's nowhere I can define the temperature of the flow. Second, When I using a certain temperature condition, it seems the fluid temperature will all reach that wall temperature after several iteration. Anyone can help with that? Thank you so much. |
I know of no limitation in the periodic boundary in CFX for temperature modelling. I suspect some other issue is causing the problem.
Can you show an image of what you are modelling and an example output file. |
The example is from the fluent help tutorial, https://www.cfd-online.com/Forums/me...ure854-p11.png this is a 2D case. To compare the results, I modeled both in 3D using fluent and CFX. In fluent, I can define the flow bulk temperature as 300K when specifying the mass flow rate, as shown https://www.cfd-online.com/Forums/me...ture844-p1.png After iteration, I got the following results for velocity and temperature field. https://www.cfd-online.com/Forums/me...ture845-p2.png https://www.cfd-online.com/Forums/me...ture846-p3.png However, when using CFX, https://www.cfd-online.com/Forums/me...ture848-p5.png first I don't know where I can specify the upstream bulk temperature for the flow, because there is no place for me to input this information in the interface dialog box. https://www.cfd-online.com/Forums/me...ture847-p4.png Still, I finish the iteration using thermal energy model, and the flow converged pretty quickly while the heat transfer is not that good. https://www.cfd-online.com/Forums/me...ture849-p6.png https://www.cfd-online.com/Forums/me...ture850-p7.png Finally I got a similar velocity with that from fluent https://www.cfd-online.com/Forums/me...ture852-p9.png but a completely different temperature field results like this https://www.cfd-online.com/Forums/me...ure853-p10.png Really confused about that. |
CFD Solver finished: Mon Dec 19 10:32:20 2016
CFD Solver wall clock seconds: 7.1925E+01 ================================================== ==================== Termination and Interrupt Condition Summary ================================================== ==================== CFD Solver: Run duration reached (Maximum number of outer iterations) ================================================== ==================== Boundary Flow and Total Source Term Summary ================================================== ==================== +--------------------------------------------------------------------+ | U-Mom | +--------------------------------------------------------------------+ Boundary : symmetry34 1.7396E-23 Boundary : wall1 -3.6313E-07 Boundary : wall2 -3.6471E-07 Domain Interface : flowinterface (Side 1) 9.5685E-07 Domain Interface : flowinterface (Side 2) -2.2901E-07 ----------- Domain Imbalance : 1.2790E-13 +--------------------------------------------------------------------+ | V-Mom | +--------------------------------------------------------------------+ Boundary : symmetry1 -4.6013E-07 Boundary : symmetry2 4.8665E-08 Boundary : symmetry34 7.7580E-07 Boundary : wall1 3.8661E-08 Boundary : wall2 -4.0300E-07 Domain Interface : flowinterface (Side 1) -9.2033E-08 Domain Interface : flowinterface (Side 2) 9.2033E-08 ----------- Domain Imbalance : 1.4211E-13 +--------------------------------------------------------------------+ | W-Mom | +--------------------------------------------------------------------+ Boundary : sym12 -6.8212E-13 Boundary : symmetry34 -3.4704E-26 Boundary : wall1 1.9230E-12 Boundary : wall2 -1.6828E-13 Domain Interface : flowinterface (Side 1) 1.3119E-11 Domain Interface : flowinterface (Side 2) -1.3119E-11 ----------- Domain Imbalance : 1.0726E-12 +--------------------------------------------------------------------+ | P-Mass | +--------------------------------------------------------------------+ Domain Interface : flowinterface (Side 1) 5.0000E-05 Domain Interface : flowinterface (Side 2) -5.0000E-05 ----------- Domain Imbalance : 0.0000E+00 +--------------------------------------------------------------------+ | H-Energy | +--------------------------------------------------------------------+ Boundary : wall1 4.6752E-07 Boundary : wall2 2.5518E-07 Domain Interface : flowinterface (Side 1) 2.1295E+01 Domain Interface : flowinterface (Side 2) -2.1295E+01 ----------- Domain Imbalance : 0.0000E+00 +--------------------------------------------------------------------+ | Normalised Imbalance Summary | +--------------------------------------------------------------------+ | Equation | Maximum Flow | Imbalance (%) | +--------------------------------------------------------------------+ | U-Mom | 9.5685E-07 | 0.0000 | | V-Mom | 9.5685E-07 | 0.0000 | | W-Mom | 9.5685E-07 | 0.0001 | | P-Mass | 5.0000E-05 | 0.0000 | +----------------------+-----------------------+---------------------+ | H-Energy | 2.1295E+01 | 0.0000 | +----------------------+-----------------------+---------------------+ ================================================== ==================== Wall Force and Moment Summary ================================================== ==================== Notes: 1. Pressure integrals exclude the reference pressure. To include it, set the expert parameter 'include pref in forces = t'. +--------------------------------------------------------------------+ | Pressure Force On Walls | +--------------------------------------------------------------------+ X-Comp. Y-Comp. Z-Comp. Domain Group: fluid wall1 2.6798E-07 4.6238E-08 -1.6137E-14 wall2 2.6924E-07 3.1800E-07 -1.3205E-14 ----------- ----------- ----------- Domain Group Totals : 5.3722E-07 3.6424E-07 -2.9342E-14 +--------------------------------------------------------------------+ | Viscous Force On Walls | +--------------------------------------------------------------------+ X-Comp. Y-Comp. Z-Comp. Domain Group: fluid wall1 9.5143E-08 -8.4900E-08 -1.9065E-12 wall2 9.5474E-08 8.5001E-08 1.8132E-13 ----------- ----------- ----------- Domain Group Totals : 1.9062E-07 1.0117E-10 -1.7252E-12 +--------------------------------------------------------------------+ | Pressure Moment On Walls | +--------------------------------------------------------------------+ X-Comp. Y-Comp. Z-Comp. Domain Group: fluid wall1 -2.3120E-11 1.3400E-10 -2.2199E-09 wall2 -1.5900E-10 1.3462E-10 9.5425E-09 ----------- ----------- ----------- Domain Group Totals : -1.8212E-10 2.6861E-10 7.3226E-09 +--------------------------------------------------------------------+ | Viscous Moment On Walls | +--------------------------------------------------------------------+ X-Comp. Y-Comp. Z-Comp. Domain Group: fluid wall1 4.2424E-11 4.7569E-11 -1.1452E-09 wall2 -4.2503E-11 4.7738E-11 1.8926E-09 ----------- ----------- ----------- Domain Group Totals : -7.8219E-14 9.5307E-11 7.4737E-10 +--------------------------------------------------------------------+ | Locations of Maximum Residuals | +--------------------------------------------------------------------+ | Equation | Domain Name | Node Number | +--------------------------------------------------------------------+ | U-Mom | fluid | 1393 | | V-Mom | fluid | 1475 | | W-Mom | fluid | 1003 | | P-Mass | fluid | 1386 | +----------------------+-----------------------+---------------------+ | H-Energy | fluid | 2624 | +----------------------+-----------------------+---------------------+ ================================================== ==================== | False Transient Information | +--------------------------------------------------------------------+ | Equation | Type | Elapsed Pseudo-Time | +--------------------------------------------------------------------+ | U-Mom | Auto Timescale | 2.64824E+02 | | V-Mom | Auto Timescale | 2.64824E+02 | | W-Mom | Auto Timescale | 2.64824E+02 | +----------------------+-----------------------+---------------------+ | H-Energy | Auto Timescale | 2.64824E+02 | +----------------------+-----------------------+---------------------+ +--------------------------------------------------------------------+ | Average Scale Information | +--------------------------------------------------------------------+ Domain Name : fluid Global Length = 6.8511E-03 Minimum Extent = 1.0000E-03 Maximum Extent = 4.0000E-02 Density = 9.9700E+02 Dynamic Viscosity = 8.8990E-04 Velocity = 7.0714E-03 Advection Time = 9.6885E-01 Reynolds Number = 5.4277E+01 Thermal Conductivity = 6.0690E-01 Specific Heat Capacity at Constant Pressure = 4.1817E+03 Prandtl Number = 6.1316E+00 Temperature Range = 1.5259E-04 +--------------------------------------------------------------------+ | Variable Range Information | +--------------------------------------------------------------------+ Domain Name : fluid +--------------------------------------------------------------------+ | Variable Name | min | max | +--------------------------------------------------------------------+ | Density | 9.97E+02 | 9.97E+02 | | Specific Heat Capacity at Constant Pressure| 4.18E+03 | 4.18E+03 | | Dynamic Viscosity | 8.90E-04 | 8.90E-04 | | Thermal Conductivity | 6.07E-01 | 6.07E-01 | | Static Entropy | 1.23E+03 | 1.23E+03 | | Velocity u | -1.58E-03 | 1.29E-02 | | Velocity v | -8.31E-03 | 8.32E-03 | | Velocity w | -1.61E-05 | 1.20E-05 | | Pressure | -5.27E-02 | 1.18E-01 | | Temperature | 4.00E+02 | 4.00E+02 | | Static Enthalpy | 4.26E+05 | 4.26E+05 | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | CPU Requirements of Numerical Solution | +--------------------------------------------------------------------+ Subsystem Name Discretization Linear Solution (secs. %total) (secs. %total) ---------------------------------------------------------------------- Momentum and Mass 3.76E+01 51.2 % 5.60E+00 7.6 % Heat Transfer 1.34E+01 18.3 % 2.35E+00 3.2 % -------- ------- -------- ------ Subsystem Summary 5.10E+01 69.5 % 7.95E+00 10.8 % Variable Updates 1.11E+01 15.1 % GGI Intersection 1.00E-03 0.0 % Search Calculations 9.99E-04 0.0 % File Reading 4.00E-03 0.0 % File Writing 4.70E-02 0.1 % Miscellaneous 3.26E+00 4.4 % -------- Total 7.34E+01 +--------------------------------------------------------------------+ | Job Information at End of Run | +--------------------------------------------------------------------+ Host computer: ZC-PC (PID:6112) Job finished: Mon Dec 19 10:32:20 2016 Total wall clock time: 7.336E+01 seconds or: ( 0: 0: 1: 13.364 ) ( Days: Hours: Minutes: Seconds ) End of solution stage. +--------------------------------------------------------------------+ | The results from this run of the ANSYS CFX Solver have been | | written to E:/Workbench files/Tutorial_Periodic | | Flow_pending/dp0_CFX_2_Solution_8/Fluid Flow CFX_001.res | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | For CFX runs launched from Workbench, the final locations of | | directories and files generated may differ from those shown. | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. Not sure whether this will help or not. |
You are right, you cannot do temperature control in translation periodic boundaries.
No matter, with a source term you can do anything :). Put a source term on the upstream periodic face (under the "Sources" tab) and make it pull the temperature back to 300K. Set a total source term to -C*(T-300[K]) and a source term coefficient of -C. Define the CEL expression C as a large number, maybe 1000000. Some discussion about doing similar things with source terms: https://www.cfd-online.com/Forums/cf...subdomain.html |
https://www.cfd-online.com/Forums/me...ure859-pp7.png I also have tried this in CFX either at the inlet face boundary source https://www.cfd-online.com/Forums/me...ure855-pp1.pnghttps://www.cfd-online.com/Forums/me...ure856-pp2.png or outlet face boundary source, https://www.cfd-online.com/Forums/me...ure857-pp4.pnghttps://www.cfd-online.com/Forums/me...ure858-pp5.png While the outlet source case result seems similiar but still not right. |
The outlet case is giving the results I expect. I am not sure why the inlet case did not converge - are you using a total energy model or just thermal energy?
I don't know what the fluent temperature results mean. I don't understand what they are showing. It does not appear to be the temperature of the first row, or the temperature of the n-th row (which is just everything at 400K, as the CFX result showed). So what is it? Source terms are terms added to the equation which can be used to modify things by adding or removing energy/momentum or whatever the conservation equation is conserving. In this case it adds or removes an amount of energy required to return the air to 300K. So the air comes out at 300K. Quote:
The help for fluent states that t_bulk "sets the inlet bulk temperature for periodic heat transfer calculations" - that does not expand my knowledge very much.
I don't understand what Fluent has done such that some of the inlet boundary is not at 300K. And I can't see what the difference between the bulk temp and the inlet temp is when you have only got the inlet to define it at. If the flow is compressible it could be the total temperature - but the Fluent document says this approach is not valid for compressible flows, and the velocities in this example are low so that does not seem applicable. |
Try to refer to section 13.4 (13.4.2) of Fluent Users's Guide.
It took me ages to upload some pictures about this from the fluent help, bad network.
The case is incompressive, so I just use the thermal energy. From the fluent result, I guess the temperature result is the "first row" result, which I am not sure about that. https://www.cfd-online.com/Forums/me...re860-ppp1.png I got some screenshot here explaining how fluent deal with this problem. https://www.cfd-online.com/Forums/me...er-page-01.pnghttps://www.cfd-online.com/Forums/me...er-page-04.pnghttps://www.cfd-online.com/Forums/me...er-page-05.pnghttps://www.cfd-online.com/Forums/me...er-page-06.pnghttps://www.cfd-online.com/Forums/me...er-page-12.png It seems the fluent result is reasonable. Still, Horrocks, thanks for your explaination about the source. I can understand why add the source, but still can not understand how can this be achieved by adding this source term to the energy equation. How do this manage to pull the collant output temperature to 300K? Confused. |
I see what Fluent is doing now. It is not modelling temperature but models a scaled temperature. Thanks for clarifying that.
The CFX model you did before is the first row result. CFX has no built in equivalent of the scaled temperature but I think you will be able to model it by defining scaled temperature as a user variable and applying the conditions specified in the Fluent manual. |
The source term gets the temperature difference from 300K and applies heat (or cooling) to get the temperature back to 300K.
But the last page about the postprocessing of the temperature results says the result is actual temperature; if it is the scaled one, it should be periodic in the flow direction, but it's not.
Also the fluent tutorial explains the temperature field this way "The contours in Figure 4.5 reveal the temperature increase in the fluid due to heat transfer from the tubes. The hotter fluid is confined to the near-wall and wake regions, while a narrow stream of cooler fluid is convected through the tube bank." It can be seen from the first page of my last post. |
It looks like they have converted the scaled temperature back to real temperature for the post processing using eqn 14-21 from your post. That is why it is not periodic.
Yeah I guess so, I'll try the additional variable to see whether it can achieve the same goal Thanks Horrocks
Going along with what Glenn suggested, making the inlet 300K. I believe you want the energy source term to be uniform at the interface, meaning cool all the fluid by the same amount, don't make it the same temperature.
Say you set this to take 100 Watts out @ the interface uniformly, then your fluid temperature will converge on where you would have 100W of heat transfer. You can monitor this, and change it on the fly in the solve manager until your bulk temperature is 300K, or whatever you want it to be. You could also find a nice curve for bulk temperature vs heat transfer. Maybe you already knew that, it was a pretty long/detailed post with a lot of good ideas floating around. |
Good idea Erik. If you make the source term an even 100W (or whatever the amount should be) you should get results equivalent to the Fluent one.
Hi Erik, it seems you proposed a promising way to do this, I get what you mean, but I do not quite understand how to achieve that. Could you please explain it in detail? or any reference thread. I find it difficult to look for the related post without understand it.
How can I specify the fluid is cooled by the same amount? yeah, the inlet temperature profile (not the uniform 300K) should be something associated with the velocity profile, with its bulk temperature is 300K. How can I get that inlet temperature profile? In the fluent results, everypoint temperature value in the outlet is the corresponding point temperature value in the inlet plus the same delta T. Horrocks, I don't manage to achieve this using the additional variables. You can see the eqution 14-22 in former post picture, I guess I need to find the T profile of the inlet, while knowing the velocity profile and bulk temperature. Kind of impossible to do this with out using fortran to do some iteration work. Any convenient idea? |
Erik's idea is much simpler so I suggest you do that. Put a source term on the inlet or outlet boundary face set to a flux of -100[W] or whatever heat loss is appropriate (although you might need need to convert that to W/m^2 or similar to get the units right), and zero source term coefficient. This will replace the previous suggestion of a total source term set to -C(T-300[K]).
