How to calculate Reynolds Stress terms using the Boussinesq approximation? |
July 7, 2023, 14:06 |
Ashkan Kashani
Rep Power: 10 |
Hello all,
I need to define three field variables, namely UV, UU, and VV, which are supposed to provide estimates of Reynolds stress terms (i.e. , and ) based on the Boussinesq approximation. where and are the eddy viscosity and the turbulence kinetic energy, respectively, which are known from the RANS model adopted in my study (i.e. GeKo model). So far so good. However, since I'm using a homogeneous multiphase model (i.e. air and water in the domain), multiple combinations of the relevant variables are available in CFX-pre for substitution in the above equations. Density or Water.Density or Air.Density Eddy Viscosity or Water.Eddy Viscosity or Air.Eddy Viscosity Turbulence Kinetic Energy or Water.Turbulence Kinetic Energy or Air.Turbulence Kinetic Energy Velocity u or Water.Velocity u or Water.Superficial Velocity X or Air.Velocity u or Air.Superficial Velocity X and the same holds for . In addition, as shown in Figure 1 in the attachments, these additional variables can be defined on Water, Air or both. I just need to compare the estimated Reynolds stress with experimental data. But I'm not sure what variables and settings are most relevant. Also attached is the CCL for further details. I would really appreciate your help. Regards, Armin Last edited by Ashkan Kashani; July 11, 2023 at 15:21. |
July 7, 2023, 19:53 |
Rep Power: 143 |
Which variables are appropriate depends on many factors:
* The volume fractions - is one phase very high VF and one very low? Or both similar? * The nature of the multiphase flow - bubbles, droplets, discrete free surface? * What the paper you are comparing to say they have done * How accurate you want to be
July 11, 2023, 15:14 |
#3 | |
Ashkan Kashani
Rep Power: 10 |
Thank you for your comment.
I am comparing the Reynolds stress terms predicted by the CFD model to those obtained from Particle Image Velocimetry (PIV) in the lab. Note the PIV analysis was applied to the water domain only (the tiny tracers were injected in the water, not air). The air flow is not deemed to have any effect and therefore not of any interest. Taking all these into account, how can I set the field variables that are most comparable and relevant to the experimentally measured Reynolds stress terms? I couldn't find the exact definition of those variables in order to make a confident decision. |
July 11, 2023, 20:20 |
Rep Power: 143 |
The Water.variable and Air.variable ones are obviously the variable of their respective phases. The "variable" one is the volume fraction weighted value.
But in your case as it is a free surface flow then the volume fraction will be 0 or 1 across almost the entire domain (with only a small region of intermediate VFs at the interface). This means the "variable" value will be the same as either Water.variable or Air.Variable depending on whether the location is in the air or water. The choice of what variable to use to calculate your Reynolds stresses should be pretty obvious from that.
October 10, 2023, 15:40 |
Ashkan Kashani
Rep Power: 10 |
Hello everyone. I have another relevant question, so I will post it here.
It is easy to compute the Reynold stress based on a linear eddy viscosity model in CFX; the Reynold stress terms can be defined as new field variables through simple short expressions following the Boussinesq assumption, i.e. However, when it comes to nonlinear models like EARSM which uses a much more complicated constitutive relation as follows with This is not very straightforward to implement; I guess a piece of code is required. I am wondering if there is any easy way to compute the Reynolds stress based on the EARSM model. Could those terms be readily reported in the result file by any means? I appreciate your help. |
October 10, 2023, 17:43 |
Rep Power: 143 |
Have a look in the results file (including all the additional variables you can add in CFX-Pre) to see what is available - but I do not think that variable is reported.
So if you want to report it you will have to calculate it in user fortran or CEL.
Recommendation of paper for Reynolds Stress Model | FluidKo | Main CFD Forum | 7 | February 10, 2022 08:57 |
[ANSYS Meshing] Error in Workbench "Unable to attach to geometry file" | Jeremie84 | ANSYS Meshing & Geometry | 70 | October 25, 2017 16:03 |
Reynold's Stress not shown | anjansir | OpenFOAM Post-Processing | 0 | December 16, 2011 01:55 |
Reynolds stress distribution (presentation) | quattro123 | ANSYS | 1 | January 11, 2011 12:22 |
reynolds stress | tufito | Main CFD Forum | 3 | March 10, 2005 15:40 |
