velocity inlet: sparger
Old   May 12, 2000, 13:00
Default velocity inlet: sparger
jy
Is there a usual way to set the velocity of a gas sparger in a fluid. I imagine that the gas will decrease from the velocity in to the sparger system to the limit velocity of a bubble in a fluid
vlim2=4Dg.(rhol-rhog).g/3Cdrhog
But if you have a better way (with the pressure drop in the sparger system) you are welcome
jy (www.pfd.ie)
Old   June 30, 2000, 06:02
Default Re: velocity inlet: sparger
venugopal
i am using cfx4.3.in relation to gas velocity at sparger, i have a doubt.if you refer example 41 in the cfx4.3 online help manual,they have given a source term for gas,i.e,fmass=0.0001 and vjet =0.25.how is it possible to calculate gas velocity from this?
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
FSI- Pipe- uniform velocity profile inlet Absy Main CFD Forum 0 April 6, 2010 03:01
time varying inlet velocity Zhe Liu CFX 0 July 31, 2008 06:56
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
