PBM for polydisperse flow using MUSIG in a porous filter |
Lakshay Garg
Rep Power: 10 ![]() |
Hello all,
I am trying to model a eulerian multiphase polydisperse flow using homogenous MUSIG. The system is air(continuous) and water(polydispersed) To implement the mass transfer, I need to put a sink/source term for each size group. The problem is, I want to retrieve the number/mass of each group size in the element to calculate the source term for mass transfer. I tried using the existing CFX variables like mass(), mf and mfc, but I am not sure about the location(location should be the element itself). I also went through the "variables" file and found variables like Group I&J mass, number density etc which could be used but CFX is not accepting these variables( Form: WaterOnFilter.Group1.Mass etc) Any help or information is highly appreciated! Thanks |
Rep Power: 145 ![]() ![]() ![]() ![]() |
Are you applying the source in the volume or a subdomain or on a surface?
Lakshay Garg
Hey Glenn,
I am applying the source in a subdomain |
The x,y,z variables give the location if that is what you mean. Or did you mean some other location function?
Lakshay Garg
Thanks Glenn. The mass transfer source term depends upon the mass/number of different bins in the particular mesh element. That's why the location term should change depending upon the position of the solver. I am new to cfx and i hope it clears the problem.
Thanks again for your help! |
If you are saying that you need to get the element number (or a pointer to it or equivalent) so you can get the flow variables at that element number - CFX does not work that way.
If you want the distance from the point in a 3D domain for every node (ie a 3D field variable) you define the function sqrt(x*x+y*y+z*z). The function is evaluated at each node in the 3D domain and returns a scalar variable field. You do not need to refer to element numbers. Or have I misinterpeted your question? |
Lakshay Garg
Hey Glenn,
Many thanks for your help. Just one question, can the return variable from the function be used as a location parameter? I will try to implement it and post the result! |
Yes, a function can return a length, and the length can be used to define a position, such as Cartesian x,y,z.
cel expression, musig |
Display Modes | |
Modeling a filter bag (porous media) while having a compressible flow | SFRazavi | STAR-CCM+ | 2 | May 16, 2016 14:04 |
Laminar flow inside a filter holder problem with convergence | sachinip | FLUENT | 0 | September 4, 2015 10:53 |
unexpected flow speeds within porous zones | MasterCooler | OpenFOAM | 11 | May 2, 2012 07:48 |
Porous media flow with diffusion | albertinho | OpenFOAM | 0 | March 31, 2010 17:14 |
Two phase flow in porous media | Madhavi Krishnan | FLUENT | 3 | June 6, 2005 05:52 |
