an error in defination for fluid models
Like Tree6Likes
  • 1 Post By whyjackeyson
  • 1 Post By Opaque
  • 1 Post By namandoshi
  • 1 Post By Gert-Jan
Old   February 12, 2017, 00:30
Post an error in defination for fluid models
Jiacheng Wang
whyjackeyson is on a distinguished road
Hello everyone,
I am trying to model a simple membrane module with CFX. My current problem is an error when I define two gas materials. The error message said that one constraint component is required for the component fluid models. However, I can not find any positions to fill in the 'fluid models' page for the default domain.
I defined the option for heat transfer to be isothermal at 378K and defined the option for turbulence to be k-Epsilon. None for combustion and none for thermal radiation. Also, the options for two materials(C2H6O & H2O) both is transport equation. That's all what I have set.
I'm a new one in CFX. Hope for help and I would appreciate that very much.
jackeyson
Svetlana likes this.
whyjackeyson is offline   Reply With Quote
Old   February 13, 2017, 15:53
Opaque will become famous soon enough
One of your transport equation settings should be "Constrain"
Opaque is offline   Reply With Quote
Old   February 13, 2017, 21:09
Post
Jiacheng Wang
Just as you have said, it was solved.
Thanks a lot.
Old   April 10, 2018, 03:00
naman doshi
namandoshi is on a distinguished road
can you please explain how?
namandoshi is offline   Reply With Quote
Old   April 10, 2018, 03:01
naman doshi
Thanks a lot.
how you did it?
Old   January 29, 2021, 05:39
Edgaras
e.smigelskis is on a distinguished road
Send a message via Skype™ to e.smigelskis
Thanks a lot.
So can anyone share how to solve this issue? In my case, I have Nitrogen/Steam in the system, where the domain initially is filled with Nitrogen and then Nitrogen/Steam mixture enters.
I get an error: "In Analysis 'Flow Analysis 1' - Domain 'Default Domain': One constraint component is required for the component fluid models."
However, if in "Fluid Models", either Nitrogen or Steam option from "Transport Equation" is changed to "Constraint", then I get the following error:
"The object "/FLOW:Flow Analysis 1/DOMAINefault Domain/BOUNDARY:inlet/BOUNDARY CONDITIONS" contains the following object: "Steam" whose name is not in the set of those allowed: "Nitrogen"."
So at the end, if one of the components is "Constraint" I lose the possibility to use that component in the system.
Could anyone advice? Thanks.
e.smigelskis is offline   Reply With Quote
Old   January 29, 2021, 07:05
Gert-Jan
Gert-Jan will become famous soon enough
You should have set it as follows:
- You define a varaible composition mixture with N2 and H2O
- In the domain select the mixture as fluid.
- Then you select to either solve N2 or H2O. So one component has a mass fraction x and the other will be 1-x.
- At the initial conditions, you can set the value for x
- And at the inlet as well.
It it does not work like that, I would start over again. Or define a new variable composition mixture.
You mention steam. What do you mean with steam? Is it just water vapour? Or is it wet steam?
aero_head likes this.
Gert-Jan is offline   Reply With Quote
variety of turbulence models in cfx? hamidciv CFX 5 January 4, 2016 03:41
Eddy Viscosity Models and Reynolds Stress Models JuPa CFX 1 August 20, 2013 19:56
Eddy viscosity hypothesis versus Reynolds stress models JuPa ANSYS 0 August 12, 2013 07:20
Incompressible Turbulence models achinta OpenFOAM 4 May 27, 2010 11:35
Two-fluid models vs mixture models for bubbly flows Hansong Tang Main CFD Forum 6 December 8, 2009 04:21
