November 21, 2000, 10:54 |
Treatment of solids in multiphase flow
I am working with older version of CFX. I am using eularian eularian approach to solve flow pattern of solid and fluid. I have already solved flow field for fluid. can i give this solution as initial guess for eularian eularian way. is it necessary to define solid properties as fluid properties are done because viscosity of solids cant be defined. i would be thankful for early reply.
November 23, 2000, 02:07 |
Re: Treatment of solids in multiphase flow
You can use the 'single phase' solution as an initial guess for your 'two phase' simulation. The solids should be defined as discrete and given a sensible density and a very small viscosity (i.e. 1.0E-10). The small viscosity means that the solid phase does not undergo any viscous diffusion.
Good luck, Frank |
mesh size in Eulerian multiphase flow - liquid/solid mixture | microfin | FLUENT | 4 | December 23, 2016 13:55 |
Multiphase Flow | Pavlos | FLUENT | 0 | August 8, 2011 08:43 |
Multiphase flow in atomiser | santhosh1987 | FLUENT | 0 | May 12, 2011 04:26 |
Multiphase flow & porous media | Hisham | OpenFOAM | 3 | April 10, 2011 07:04 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
