Interpolation of Initial Values error
Old   February 27, 2017, 05:50
Default Interpolation of Initial Values error
Neys Schreiner
Neys Schreiner is on a distinguished road
Hi guys,
I am running a reasonably large problem (~11m cells) using CFX v17.0, running on a cluster. I can run the problem from an automatically initialised flow field, but when I try a restart from a previous solution I get the following error:
| Interpolation of Initial Values |
<IBM Platform MPI>: : warning, dlopen of libhwloc.so failed /apps/intel/parallel_studio_2016/impi/5.1.3.210/lib/linux_amd64/libhwloc.so: cannot open shared object file: No such file or directory
| An error has occurred in cfx5solve: |
| Error interpolating results onto the new mesh: |
| /apps/ansys/v170/CFX/bin/linux-amd64/double-int64-ifort/solver-pc- |
| mpi.exe was interrupted by signal SEGV (11) |
Has anyone seen anything like this before? Any advice would be appreciated.
Regards,
Neys
Neys Schreiner is offline   Reply With Quote
Old   February 27, 2017, 07:12
Neys Schreiner
As found in this thread, the error appears to be linked to the scheduler (SLURM).
This can be solved by adding:
unset SLURM_GTIDS
to the submission script.
Old   February 27, 2017, 10:30
misagh
misagh is on a distinguished road
I faced with that error and the problem was solved by changing the folder in which the initial res file ewas saved. Try to save your files in a shorter drive address.
Hope that works for you too.
misagh is offline   Reply With Quote
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 06:37
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
