Pressure Boundary at Outlet
Old   March 10, 2017, 13:04
Default Pressure Boundary at Outlet
AS_Aero is on a distinguished road
Hi All
I was doing a simple RANS simulation of circular Pipe flow with diffuser at one end using CFX.
The
Inlet Boundary was given massflow rate and
Outlet as static pressure =zero
Reference Pressure = 1 atm
The data sheet of the diffuser says that at inlet the operating pressure of 10 bar has a flow rate of 4 l/min.
But when I post process my results at inlet where I gave 4 L/min shows a pressure less than that or around 5 bar which makes me doubt about the boundary condition. Could someone help me to explain what could have gone wrong or is it quiet natural ? or should I do something with the reference pressure or at the outlet ?
Thanks in advance
AS_Aero is offline   Reply With Quote
Old   March 11, 2017, 05:43
Have you done the standard checks for accuracy? https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
Old   March 11, 2017, 06:04
YEs No I would say !! There is the problem. I am doubtful about the BC'ns I have applied. Or either I am confused what to give. And yes with the other parameters YEs I did play around.. Not much of a difference. I am confused about this pressure thing !!
In the experiment when you give 10 bar from the pump (barometer reading) to the pipe it has a flow rate of 5L/min. So in the simulation I gave the 5L/min so I expect a 10 bar pressure as the inlet maximum pressure right ? But thats no the case here.
Old   March 14, 2017, 09:10
Jiri
Jiricbeng is on a distinguished road
Moreover make sure about static/total pressure.
Jiricbeng is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Pressure Driven Supersonic Flow in Converging-Diverging Nozzle cdm OpenFOAM Running, Solving & CFD 7 August 28, 2019 02:37
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Low torque values on Screw Turbine Shaun Waters CFX 34 July 23, 2015 09:16
Pressure outlet boundary condition fluent_newbie FLUENT 0 December 2, 2011 00:51
