[Sponsors] | |||||
belamou
Rep Power: 18 ![]() |
Hi
Please, I am setting up a small cluster with 4 nodes ( 8 CPU , 64 cores), plus a master node (8 cores). I want to make head node participate to computation. To avoid batch & scripts and to launch solver from graphical interface. Is it a good idea ? Another point, is the cable lengths. The 4 nodes are linked to the switch through 2 meters cables, these nodes and switch are in separated room (lound), however the master (in my office) would be connected to that switch by a 15 meters cable!, Could this difference in cable lengths creates a latency during solution process ? The connection is 10GbE sfp+.. Thank you BR Sent from my SM-G360F using CFD Online Forum mobile app |
Maxim
Rep Power: 14 ![]() |
I don't have any experience in setting such a thing up and I haven't used sfp+ yet but from what I've heard, those computers should be connected with an infiniband. That might be old knowledge since your 10Gbs sfp+ sounds like quite a data throughput...
Erik
Rep Power: 24 ![]() |
I have seen slight latency increase in my 50meter infiniband cable. The other 1 meter and up to 20 meter cables all perform identically as far as I can tell. I just have the one node that is slightly slower.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Explicitly filtered LES | saeedi | Main CFD Forum | 16 | October 14, 2015 12:58 |
| simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 19:45 |
| Running CFX parallel distributed Under linux system with loadleveler queuing system | ahmadbakri | CFX | 1 | December 21, 2014 05:19 |
| Problems about distributed parallel runs | vkrastev | OpenFOAM Running, Solving & CFD | 10 | November 11, 2012 10:22 |
| HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 07:17 |
