June 5, 2001, 16:56 |
Vorticity in USRDMP
Hi
I would like to plot 2D vorticity in the Dump file. Unfortunately CFX does not provide this variable in the solver. The only option I got is to calculate this variable manually. As far as I can understand from the Solver manual, I need to set this in USRDMP and use the routine GRADV. I'm confused where should I call the GRADV. Is it in the user are 5 or 6 ? I would be very grateful if somebody could help me on this. Thanks, Budi |
June 6, 2001, 02:21 |
Re: Vorticity in USRDMP
I suggest you try both by copy and paste. Then skip the one that doesn't make sense.
Astrid |
How to implement vorticity calculations | mortain | Main CFD Forum | 0 | July 1, 2010 13:26 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
vorticity calculation at symmetryplane | benconnell | OpenFOAM | 0 | April 14, 2009 18:45 |
Vorticity Iso-Surface | John | Main CFD Forum | 0 | April 4, 2009 23:10 |
Plotting Vorticity in CFX 11 | Venkatesh | CFX | 4 | August 6, 2008 06:26 |
