ROUGHNESS HEIGHT
Old   May 21, 2001, 05:41
Default ROUGHNESS HEIGHT
Sumon
Hi everyone
Could anyone tell me what is the roughness height and its unit which is used as by default? In USRWTM there is an option to change the roughness height. I am egarly waiting for the reply and suggestions.
Regards,
Sumon
Old   May 28, 2001, 06:22
Default Re: ROUGHNESS HEIGHT
Sascha
All surfaces in technical applications liek the surface of a car are rough with a deviation in roighness height. You have it even for very smooth surfaces. In most CFD programs a standard roughness is set. But if you have a much rough surface liek sandcorn size you have to modify the wall functions for the turbulence model with the right roughness height. Normally teh roughness height is measured in 10^-6 m but in CFX you add it also in m so be aware of that !
Sascha
Old   May 29, 2001, 04:27
Sumon
Sascha
Thanks for your kind reply. But if you have a look the USRWTM, it is mentioned that for RFACT = 0.3 WOULD BE FULLY ROUGH and RFACT > 0.3 GIVES LESS ROUGHNESS. Is it correct? The equation which is used in the example, it is contradictory. Could you tell me something about this. From the equation, I think that RFACT = 0.3 WOULD BE FULLY SMOOTH and RFACT > 0.3 GIVES LESS SMOOTHNESS.
Thanks again.
Sumon
Old   June 12, 2001, 09:38
Sascha
In this case the manual is wrong. When you check with the appropriate wall function which you have to use for rough walls a dimensionless roughness height as used in USRWTM (first example) will mean an increasing roughness for this parameter when u increase it.
Setting of Roughness Constant and Height Sing FLUENT 7 June 23, 2021 14:26
UDF: for the setting of roughness height maximus FLUENT 1 September 10, 2014 16:20
Trouble with Roughness Height Dragin STAR-CCM+ 1 June 17, 2009 16:32
atmospheric roughness height Alain BASTIDE Siemens 5 December 30, 2002 05:26
atmospheric roughness height Alain BASTIDE Main CFD Forum 0 December 27, 2002 16:32
