Is it possible to put pressure as an input?
Old   April 4, 2017, 23:59
Cool Is it possible to put pressure as an input?
Chan Joo Kim
monjinz is on a distinguished road
Dear Folks
I'd like to see pressure propagation in the water, so I am therefore trying to put pressure as an input at the inlet, which will propagate to the other end(outlet).
Do you guys have any thought/idea to simulate this?
Thank you
Kind regards
monjinz is offline   Reply With Quote
Old   April 5, 2017, 14:10
Erik
evcelica is on a distinguished road
You are looking for a pressure wave propagation?
Yes, its fine to do this with a compressible fluid, but not incompressible. You will have to include the compressibility of water in your material properties.
Look up speed of sound and see what the equation looks like: sqrt(stiffness/density)
Also you need to use the speed of sound to calculate your courant number (or CFL number) not velocity. So it will require very small timesteps relative to normal transient simulations.
evcelica is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 11:34
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 19:57
InterPhaseChangeFoam ERROR shipman OpenFOAM Running, Solving & CFD 37 March 23, 2014 13:43
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
