open channel
Like Tree4Likes
  • 1 Post By ghorrocks
Old   April 8, 2017, 07:00
Default open channel
Danial
Danial1992 is on a distinguished road
dear friends,
I am going to define shear stress on surface of an open channel water flow.
how can I do it?
regards.
Danial1992 is offline   Reply With Quote
Old   April 8, 2017, 08:46
If you are using a free surface model then you will need a function which finds the surface and then applies a source term to it.
Danial1992 likes this.
Old   April 8, 2017, 18:22
Danial
Thanks for ur response , may u give me more informations , I am going to define shear sterss made by wind.instead of modeling wind to reduce solve costs.
how can I do it?
The free surface has a stable level and doesnt chand by time, could u give some example or introduce me a source.
Best regards.
Old   April 9, 2017, 08:09
It depends on what you are trying to do. I would do a literature review on this topic before proceeding. I suspect the interaction between wind and fluid is quite complex due to the waves changing the air and fluid flow conditions, so simple shear stress analogies are unlikely to be accurate.
Old   April 9, 2017, 12:37
Danial
the wind velocity is so slow (like 0.5 m/s) then it is not going to make big wave and the fluid surface will be stable. so I think shear stress could be defined instead of wind.
Old   April 9, 2017, 19:06
If you think a shear stress is OK, then simply apply a wall boundary with a shear stress.
But I would check you are in a regime where surface waves do not develop.
Old   April 10, 2017, 06:04
Danial
yeah , I considered a moving wall on fluid surface which will make a shear stress as wind flows.
thanks in advanced.
Old   April 11, 2017, 20:15
You can do it using many different methods. But you use the method which you can describe mathematically what is happening. So if you know the shear stress, use that, if you know the wall velocity (or the equivalent) then use that.
Old   April 12, 2017, 11:14
Unhappy
Danial
I just know the shear stress but how can I find equivalent wall velocity which can make the same shear stress? I didn't find any thing in theory documents about moving wall shear stress.
Old   April 12, 2017, 19:43
If you know the shear stress then just use the shear stress. Why convert it to a moving wall velocity?
Old   April 13, 2017, 02:45
Danial
How can I define shear stress on water surface (in cfx or fluent)?
Old   April 13, 2017, 03:13
In the boundary condition tab, under boundary details. Choose the "Specified Shear" option under Mass and Momentum.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
interFoam & decomposition method: scotch MacGyver OpenFOAM Running, Solving & CFD 2 May 23, 2012 08:00
