Boundary face
Old   August 17, 2001, 10:44
Default Boundary face
Alex
I'm using TASC I would like to know if it's possible to declare any part of a mesh(a surface) as a boundary face. Thx
Alex
Old   August 17, 2001, 13:19
Default Re: Boundary face
cfd guy
Alex,
I'm not sure if I understood your question but, here it goes...
You can define a face (of mesh) by two ways. One way is to use the TascBob3D tool, which you define it using line commands (text mode). And the other way, and the easier one, is to use the region manager in Tascflow GUI... Go to Tools menu and then "Region Manager", in there you can do it interactively by picking up several nodes to define a region. Once you defined a region, you can set a B.C. for it.
Good luck.
cfd guy.
Old   August 18, 2001, 10:23
Alex
Many thanks for your answer.
In fact I was a bit upset becausse the geometry I was trying to create was allready existing. In fact I had to append a new grid and the goemetry was a part of this grid. But the BC of that geometry weren't defined.
Here is the way I proceed to solve my problem. In the directory where my first gird is: *using TASCflow* FILE>APPEND GRID --> grd.new *using tascbob3d* SUCCESSFULLY READ X SUBGRID(S) FROM GRD FILE SUCCESSFULLY READ Y INTERFACE(S) FROM GRD FILE
:TASCbob3d{Topology}{1}:g
:TASCbob3d{BlockOff}{2}:e
:enter object label : REGION_4_GRD_NEW
:define region : [xi:yi,xj:yj,xk:yk]:GRD.NEW
:TASCbob3d{BlockOff}{3}
:x(ur choice)
:1(for solid)
:0(to exit)
:TASCbob3d{BlockOff}{6}:q
:TASCbob3d{BlockOff}{7}:w
And it's ok!
My problem remains...Is it possible to append directly the boundary conditions of my GRD.NEW when I append the geometry?
Alex
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 01:54
