Connecting a rotating and a stationary domain |
April 20, 2017, 12:44 |
Rep Power: 9 |
Dear CFD-experts,
I´m a student at a german university and trying to simulate a uav (airplane) in Ansys CFX for a seminar paper. To include the effect of a turning prop I thought I could use an empty rotating domain connected to a stationary domain. I connected them by domain interfaces with following settings. Interface Models: - Option: General Connection - Frame Change/Mixing Model: Frozen Rotor - Pitch Change: Automatic Now my problem is that the flux in the rotating domain stops rotating immediately at the end of the domain. Can you please give me instructions how to solve my problem? Please compare my explanation to the attached picture of a simple test-simulation. Test.JPG |
April 20, 2017, 18:48 |
Rep Power: 143 |
You have missed the entire point of frames of reference....
A frame of reference can be seen as simply a grid system against which velocities are measured. Whether the frame of reference is rotating or not makes no difference to the actual flow, only on what you measure its velocity as. And empty domain, whether rotating or not, has no effect on the flow. And that is what you are seeing. The corkscrew streamlines in the rotating domain is explained in this FAQ: https://www.cfd-online.com/Wiki/Ansy...f_reference.3F If you want to introduce some swirl into the flow then use a momentum source term with a function which swirling momentum. Do not use a rotating frame of reference, this can be done in the stationary frame of reference the rest of your model is in. |
April 21, 2017, 05:20 |
Rep Power: 9 |
Dear ghorrocks,
thanks a lot for the fast response. I have now added a momentum source to my simulation but i got a problem with the function which swirls the momentum. I searched the forum but i didn´t find good examples or a way to create such a function. I´ve got no experience with such things. |
April 21, 2017, 19:50 |
Rep Power: 143 |
If the axis of the swirl is the origin, then
Theta = arctan2(y,x) Radius = sqrt(x*x+y*y) X_Mom_Source = C*Radius*sin(Theta) Y_Mom_Source = C*Radius*cos(Theta) Where C is the strength of the swirl in appropriate units. I forget if arctan2 is the correct function but it is something like that. You might also be able to do some simplification of it if you feel adventurous. |
April 22, 2017, 07:31 |
Rep Power: 9 |
I Got it. Thanks a lot!
aircraft, airplane, interface defining, rotating domain |
Rotating or stationary domain in pump/turbine cavity | Christian Høy | CFX | 3 | March 17, 2017 06:03 |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 11:16 |
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. | srijithbbk | CFX | 5 | February 22, 2016 04:20 |
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
[ICEM] Meshing Simple rotating domain in a External stationary domain | sreenivas | ANSYS Meshing & Geometry | 0 | January 26, 2012 22:57 |
