How to modify the model?
Old   November 21, 2001, 12:00
Default How to modify the model?
cfxbeginer
How can I modify the model of CFX.Only by complify a Fortran file?Is there another way?
Old   November 27, 2001, 05:43
Default Re: How to modify the model?
arjun s y
can you please dilate it?
Old   November 28, 2001, 12:20
cfxbeginer
For example, I want to add a item to the momentum conservation equation.
Old   November 29, 2001, 23:31
arjun s y
ohh ..let me check ..if i could do it i will let you know ..
arjun
Old   November 30, 2001, 22:20
arjun s y
i gave it a thought .. i din't try it due to some probs but the philosophy should be like this .. take the model eqauation ..it would be of the form
d(ro*u)/dt + A * d(ro*u*u)/dxi + B * d(J)/dxi = S1 + S2
now here in this A and B are some constants (see the model carefully) and S1 and S2 are source terms ... now to set the model ..what you should do is set A , B to zero (if you need) and set S1 = some expression what you need ..say for example .. A = 0, B=0 S2 = 0 and S2 = C * exp(kT) seth the model
d(ro*u)/dt = C*exp(kT)
done ...so read manual and you may use fortran to set this .. please reply ..
arjun
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
about Subgrid-scale model impecca OpenFOAM Running, Solving & CFD 4 December 20, 2013 10:36
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
