April 27, 2017, 02:38 |
Simulation of H2/air mixture in a tube
marharyta
Rep Power: 8 |
Hi!
Now I am working on a simulation of H2/air mixture in a tube. I read that suitable for this task is a model Finite rate chemistry. Ignition model using the expression: x1=0[m] y1=0[m] z1=0[m] T1=1000[K]*(if(abs(Z-z1)<0.01[m],1,0)*if(abs(Y-y1)<0.01[m],1,0)*if(abs(X-x1)<0.01[m],1,0))+273[K]*(1-if(abs(Z-z1)<0.01[m],1,0)*if(abs(Y-y1)<0.01[m],1,0)*if(abs(X-x1)<0.01[m],1,0)), and use this temperature in domaine initialization. But the results of calculations are non-physical. Maybe, somebodycould send me a similar case for reference? I am a freshhand. Any suggestions will be appreciated! Thanks! |
April 27, 2017, 07:22 |
Rep Power: 143 |
If the results are non-physical that suggests your ignition model is non-physical. I would have thought a constant fixed temperature of 1000K in a small region which then jumps to a constant temperature of 273K would be a pretty poor model of an actual ignition source.
April 27, 2017, 07:33 |
#3 | |
marharyta
Rep Power: 8 |
April 27, 2017, 07:40 |
Rep Power: 143 |
What is your ignition source? A spark? A pilot flame? A high temperature source?
April 27, 2017, 07:44 |
marharyta
Rep Power: 8 |
April 27, 2017, 07:59 |
Rep Power: 143 |
Sparks are usually a known amount of energy in a very small volume. So use a small source region and apply the spark energy as a heat source (probably as Watts).
Note that you often have to give numerical models of combustion a bit more of a kick to get them started than you do real combustion. So you might need to give it a bit of extra energy to start if off. |
April 27, 2017, 08:09 |
#7 | |
marharyta
Rep Power: 8 |
If I will have some question, can I write you directly? |
April 27, 2017, 18:10 |
Rep Power: 143 |
I do not answer CFD questions by PM. Post them on the forum.
April 27, 2017, 22:38 |
#9 |
Rep Power: 32 |
Why are the results non-physical ? The gases do not react ? or the maximum temperature is higher than expected ?
If the latter one, you should be able to compute the adiabatic temperature for a mixture of H2, N2, O2 to verify the maximum temperature. Be careful with reading reported adiabatic temperatures w/o inspecting which species are present in the mixture. Any additional information might help those in the forum to help you. |
May 11, 2017, 10:01 |
#10 |
marharyta
Rep Power: 8 |
Now I understand that the use of models Finite rate chemistry not allow me to evaluate the rate of spread of flame. So, for my task is only acceptable model of Burning Velocity Model (BVM).
In the setting of the model BVM are correlations Zimont, Peters and Mueller. What correlation must be used in my task? |
combastion, h2/air |
3D Mixture Gas Simulation | wjbvg5 | ANSYS | 0 | January 9, 2017 16:57 |
Shock Tube Simulation in Ansys Fluent | MHS78 | CFD Freelancers | 0 | July 28, 2016 07:12 |
3d flow simulation of staggered fin tube heat exchanger | mallikarjuna | FLUENT | 0 | April 9, 2014 23:57 |
Solver for vortex tube simulation | gauravsharma2080 | FLUENT | 0 | September 20, 2012 14:43 |
Problems on H2/air CFX simulation | xulixian | OpenFOAM Running, Solving & CFD | 2 | April 14, 2009 15:00 |
