[Sponsors] | |||||
Ali karimi
Rep Power: 10 ![]() |
Hey guys, I wanna simulate a heat exchanger with external and internal flows, the internal flow is water that it's properties depends on temerature. My problem is I can't write suitable expression for it, and before it, is it the correct way to write an expression for it? Or there is another way?
By the way my data has been attached, help me in writing expression please IMG_20170501_160911.jpeg Sent from my SM-N920C using CFD Online Forum mobile app |
Rep Power: 34 ![]() |
Dynamic Viscosity = ( -4.E-10 [K^-5] * T^5 + \
7.E-07 [K^-4] * T^4 + \ 5.E-04 [K^-3] * T^3 + \ .... ) * 1 [Pa s] I assumed the chart is in SI units, adjust as needed. |
Ali karimi
Tnx dude I'll test it
Last edited by wyldckat; May 1, 2017 at 17:24. Reason: removed uninterpreted unicode characters |
Erik
Rep Power: 24 ![]() |
Remember to include more sig figs if needed. I usually use the "text" option for the numbers in excel to show the most digits.
You can also import a table: save numbers as "text tab delimited" Create a user function in CFX Pre and import that table. |
Ali karimi
ok finally i found how to write an expression
![]() but i have another problem when i start the run it gives me an error, after struggling with CFD-pre if found i forgot to initialize the domain, the solution started but it gives me another error, can someone help to find what the problem is? the screenshot attached https://ibb.co/eGhr6Q https://ibb.co/d3A00k https://ibb.co/dXiymQ https://ibb.co/fiY9t5 https://ibb.co/bPhPRQ https://ibb.co/dahf0k
Life is fluid... Last edited by wyldckat; May 1, 2017 at 17:23. Reason: removed embedded image mechanism and exposed links |
I would run the case as Isothermal first to see if it works at the expected temperature operating range; then, I would try a more complex setup.
Ali karimi
i found the problem, it's cuz of high temp that make vis negative and it isnt physical
Life is fluid... |
Ali karimi
hey
![]() finally i fixed the expressions but when i set everything in material i found an warning that doesnt let solution converged. the warning is this: Table generation controls are not set for the following materials: 'Real Water'. Please ensure that the default pressure and temperature tabulation ranges are appropriate for your setup. maybe anyone help
Life is fluid... |
#9 |
Erik
Set the table range in your material properties for Real Water.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [openSmoke] libOpenSMOKE | Tobi | OpenFOAM Community Contributions | 562 | January 25, 2023 10:21 |
| Static Temperature / Opening Temperature | JulianP | CFX | 12 | April 10, 2019 19:00 |
| Temperature dependent now-newtonian viscosity | mozafarie | FLUENT | 2 | March 22, 2014 01:19 |
| Viscosity for Granular Temperature Model | vagaikwa | FLUENT | 0 | February 24, 2013 04:42 |
| Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 07:08 |
