CFX-POST camera views
Old   October 21, 2002, 09:52
Default CFX-POST camera views
Nandu
How do u change the camera view to be normal to an arbitrary plane you have created in CFX POST?
cheers nandu
Old   October 22, 2002, 16:08
Default Re: CFX-POST camera views
cfd guy
I believe that you must change the camera view manually using the mouse. But if you find another way, please tell us.
Regards, cfd guy
Old   October 22, 2002, 17:12
Robin
Hi Nandu,
The following CCL defines the camera view. Open a command editor and enter this CCL with the pivot point and Rotation setting you want.
CAMERA:Camera 1
Option = Pivot Point and Rotation
Pivot Point = 5, 0.5, 0.5
Rotation = -90, 0, 0
END
Regards,
Robin
P.S.: To see the CCL for a view, first save the view, then save the state to file and look for the view object in your state file (to make it even easier, save only the Camera object to the state file).
Old   May 1, 2017, 09:56
Ramin
rmn_990 is on a distinguished road
in the right bottom corner of the workspace you can see the refrence frame of your case data.
by clicking on each direction of that you can change the direction automatically.
rmn_990 is offline   Reply With Quote
CFX post legend modification mactech001 CFX 3 December 25, 2011 22:12
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
CFX Post processing aditya CFX 1 July 6, 2008 12:09
Chart Generation in CFX Post Vadim Baines-Jones CFX 2 August 28, 2007 09:14
Tecplot for CFX post processing pantangi goud CFX 2 August 24, 2005 16:42
