Reference Pressure with RGP table - Out of Bounds message even though it isn't?
Old   May 2, 2017, 18:56
Default Reference Pressure with RGP table - Out of Bounds message even though it isn't?
Erik
evcelica is on a distinguished road
I'm using an RGP table that goes from 15 psia to 75 psia. My minimum pressure in my simulation is ~33 psi, max is 55 psia. Yet I'm getting an out of bounds error for absolute pressure. Does this have anything to do with my reference pressure? I set it for the outlet pressure of 33 psi Why would it tell me out of bounds when it isn't? Everything looks to make sense in the results as far as I can tell.
Here is what the table bounds errors look like:
| Independent variables went out of bounds while computing the |
| variables listed below using table interpolation. In each case |
| the bounds error was handled by clipping or extrapolation. |
| If this situation persists, consider increasing the table range. |
| Location Name : LXe Domain |
| Mesh location : VERTICES |
| Routine : Post_soln |
| Partition : 10 |
| Variable Name : Density |
| Ind. Variable : Absolute Pressure |
| Bound : Lower |
| Min Value : 2.2708E+05 |
| Handled By : Clipping |
| Partition : 10 |
| Variable Name : Total Temperature |
| Ind. Variable : Total Pressure |
| Bound : Lower |
Long List of these. All saying independent variable is absolute pressure or total pressure.
evcelica is offline   Reply With Quote
Old   May 2, 2017, 19:40
Do you get bonds error when you use a simple material model (eg ideal gas?).
It should not have anything to do with the reference pressure, but if the reference pressure is poorly set it might contribute to numerical instability which leads to things like bounds errors.
Are you sure these bounds errors are not physical?
Old   May 2, 2017, 22:13
Erik
I didn't get a bounds error when I was running Liquid Xenon. But now with gaseous Xenon and an RGP table I get these bounds errors. 2.2708E+5 Pa is ~33 psia, which is about my outlet pressure, and that makes sense. My RGP table goes down to 15 psia, but it is acting is if my table stops somewhere above 33 psia, since it is giving me these warning messages.
I'll have to try to look at my rgp table and make sure it goes down to 15 psia, but it is 75 MB of text.....sigh.
I'll probably just make a new one with a larger range and see if I still get the error.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
It would be wonderful if a tool for FoamToTecplot is available luckyluke OpenFOAM Post-Processing 165 November 27, 2012 07:54
about reference pressure adam2008 CFX 1 May 17, 2011 09:03
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
