January 17, 2002, 09:04 |
meshing in CFX 5.5
Hi all
All are aware that CFX5.5 has a automated mesh generated,giving us no control over the mesh quality, What I am interested is that is there a way we can control the mesh quality using something like expert parameters in build where we can say that the mximinum skewness should not exceed 0.6 OR is there a better way to do it other than mesh controls. As mesh adaption does not necessarily improve the mesh control. Looking forward to your contributions............ thanks henry |
January 17, 2002, 20:08 |
Re: meshing in CFX 5.5
Unfortunately there is no direct way to do this in CFX-Build. The first thing is that you have to make sure beforehand that you have a B-rep solid with a decent surface representation. See the meshing and CAD tutorial for some pointers on this.
One general problem with doing what you say is, depending on your geometry, is that it might be impossible for the mesher to generate a mesh with whatever "indices" you define. Furthermore, metrics like "skewness" and "aspect ratio", especially on a tetrahedral or hybrid mesh may not have anything to do with how well the solver performs an a particular grid, or with how accurate your solution will be. Neale. |
January 18, 2002, 13:04 |
In response to Henry, you use the mesh controls to avoid large aspect ratios. To say that they cause this problem isn't true.
If you put them in sensible places and use the proximity function, then there wont be a problem. I find the mesh controls a very powerful tool to enable me create a mesh quickly and easily. |
January 19, 2002, 01:50 |
thanks NEALE and BILL
Hi
thanks for your valuable suggestions, I would like to clarify further things : This is the first time someone has told me that aspect ratio has no effect on the solver. please brief me on this. thanks once again Henry |
January 26, 2002, 01:08 |
Re: thanks NEALE and BILL
Henry,
I'm sorry if I came across as trying to suggest that high aspect ratio cells "never" have an effect. Let me clarify. I was just saying that some of the "standard" metrics, such as aspect ratio and skewness, are not necessarily the right metric to be looking at when deciding upon the quality of the mesh. Unfortunately the proper metrics are not available in CFX-5. The quality of the mesh is really decided when you see how the solver behaves on it for a particular problem. The solver's behaviour on a particular mesh can be generally determined by the quality of linear coefficients which are assembled and sent to the linear solver. A good metric, which is not available, would be to look at the diagonal dominance of each control volume equation for a diffusion equaiton, and highlight control volumes which have a diagonal/offdiagonal ration >> 1. The solver will completely blow if this is the case. Hopefully CFX will eventually add this and some other mesh quality indices along these lines. Neale |
Problem with meshing long, thin faces in CFX | Martin | CFX | 3 | January 8, 2009 20:51 |
2D simulation - ICEM meshing for CFX question | Ben Makhal | CFX | 5 | April 11, 2007 08:44 |
meshing problems with CFX 10 | Cedric PERE | CFX | 1 | March 15, 2007 18:09 |
CFX meshing with Workbench | anna | CFX | 1 | December 19, 2006 14:35 |
Question about meshing / solution scheme of CFX | Coriolius | CFX | 8 | August 1, 2004 18:39 |
