August 9, 2018, 05:17 |
CFX Solver Manager ended with Error
Rep Power: 7 |
Hi guys,
The design that i want to simulate is a U shape oscillating water column. I have simulated my design before and it works but when i repeat it again with different parameters but still with the same scale (just change some parameters) it shows error at the cfx solver manager. Is there solution for this problem? Thanks The error is as below: | Writing transient file 27_full.trn | | Name : Transient Results 1 | | Type : Standard | | Option : Every Timestep | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | create_indextable: stored index is wrong: missing start tag | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | iif_open: unable to read the stored index, attempting to rebuild | | it | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | recreate_indextable: warning: file was not closed correctly, data | | may be inconsistent | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | create_indextable: stored index is wrong: missing start tag | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | iif_open: unable to read the stored index, attempting to rebuild | | it | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | cfxreadString: read too many characters: A | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | recreate_indextable: dataset length of zero in dataset at offset | | 47942198 (format FR): assuming incomplete file and terminating sc- | | an. | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | iocnt: open the primary file failed | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | OpenFile: open primary file failed | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine OpenFile | | | | | | | | | | | +--------------------------------------------------------------------+ End of solution stage. |
August 9, 2018, 05:51 |
#2 | |
Lance
Rep Power: 22 |
August 9, 2018, 06:00 |
Rep Power: 7 |
i have rerun it several times but it still crash with this error. for the disk space is it the hard disk space( local disk C)? if yes I have plenty of disk space available
August 9, 2018, 06:28 |
Rep Power: 143 |
I have never seen that error before so do not know what is causing it.
Do you get it if you change to serial, local parallel or distributed parallel? Or different parallel implementations (Intel MPI etc)? If that does not help please post your CCL.
August 9, 2018, 07:04 |
Rep Power: 7 |
Hi
i used intel mpi local parallel before this and this is my ccl # State file created: 2018/08/09 18:36:14 # Build 19.0 2017-12-01T23:36:31.332000 LIBRARY: CEL: EXPRESSIONS: D = 0.1[m] H = 0.7[m] HydroP = fluidDen*g*(WatH-y)*WatVF L = 5.5[m] P = 1[s] Vel U = (pi/(2*P))*H*e^((-2*pi*D)/L)*cos(2*pi*((x/L)-(t/P))) Vel V = (pi/(2*P))*H*e^((-2*pi*D)/L)*sin(2*pi*((x/L)-(t/P))) WatH = 0.5[m] WatVF = if(y<=WatH,1,0) fluidDen = 998[kg m^-3] END END MATERIAL: Air Ideal Gas Material Description = Air Ideal Gas (constant Cp) Material Group = Air Data, Calorically Perfect Ideal Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 28.96 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-2 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END MATERIAL: Air at 25 C Material Description = Air at 25 C and 1 atm (dry) Material Group = Air Data, Constant Property Gases Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Density = 1.185 [kg m^-3] Molar Mass = 28.96 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 1.0044E+03 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 1.831E-05 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 2.61E-02 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 0.01 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 0.003356 [K^-1] END END END MATERIAL: Aluminium Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2702 [kg m^-3] Molar Mass = 26.98 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 9.03E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 237 [W m^-1 K^-1] END END END MATERIAL: Copper Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 8933 [kg m^-3] Molar Mass = 63.55 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 3.85E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 401.0 [W m^-1 K^-1] END END END MATERIAL: Soot Material Group = Soot Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 2000 [kg m^-3] Molar Mass = 12 [kg kmol^-1] Option = Value END REFERENCE STATE: Option = Automatic END ABSORPTION COEFFICIENT: Absorption Coefficient = 0 [m^-1] Option = Value END END END MATERIAL: Steel Material Group = CHT Solids, Particle Solids Option = Pure Substance Thermodynamic State = Solid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 7854 [kg m^-3] Molar Mass = 55.85 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4.34E+02 [J kg^-1 K^-1] END REFERENCE STATE: Option = Specified Point Reference Specific Enthalpy = 0 [J/kg] Reference Specific Entropy = 0 [J/kg/K] Reference Temperature = 25 [C] END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 60.5 [W m^-1 K^-1] END END END MATERIAL: Water Material Description = Water (liquid) Material Group = Water Data, Constant Property Liquids Option = Pure Substance Thermodynamic State = Liquid PROPERTIES: Option = General Material EQUATION OF STATE: Density = 997.0 [kg m^-3] Molar Mass = 18.02 [kg kmol^-1] Option = Value END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 4181.7 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1 [atm] Reference Specific Enthalpy = 0.0 [J/kg] Reference Specific Entropy = 0.0 [J/kg/K] Reference Temperature = 25 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 0.6069 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END THERMAL EXPANSIVITY: Option = Value Thermal Expansivity = 2.57E-04 [K^-1] END END END MATERIAL: Water Ideal Gas Material Description = Water Vapour Ideal Gas (100 C and 1 atm) Material Group = Calorically Perfect Ideal Gases, Water Data Option = Pure Substance Thermodynamic State = Gas PROPERTIES: Option = General Material EQUATION OF STATE: Molar Mass = 18.02 [kg kmol^-1] Option = Ideal Gas END SPECIFIC HEAT CAPACITY: Option = Value Specific Heat Capacity = 2080.1 [J kg^-1 K^-1] Specific Heat Type = Constant Pressure END REFERENCE STATE: Option = Specified Point Reference Pressure = 1.014 [bar] Reference Specific Enthalpy = 0. [J/kg] Reference Specific Entropy = 0. [J/kg/K] Reference Temperature = 100 [C] END DYNAMIC VISCOSITY: Dynamic Viscosity = 9.4E-06 [kg m^-1 s^-1] Option = Value END THERMAL CONDUCTIVITY: Option = Value Thermal Conductivity = 193E-04 [W m^-1 K^-1] END ABSORPTION COEFFICIENT: Absorption Coefficient = 1.0 [m^-1] Option = Value END SCATTERING COEFFICIENT: Option = Value Scattering Coefficient = 0.0 [m^-1] END REFRACTIVE INDEX: Option = Value Refractive Index = 1.0 [m m^-1] END END END END FLOW: Flow Analysis 1 SOLUTION UNITS: Angle Units = [rad] Length Units = [m] Mass Units = [kg] Solid Angle Units = [sr] Temperature Units = [K] Time Units = [s] END ANALYSIS TYPE: Option = Transient EXTERNAL SOLVER COUPLING: Option = None END INITIAL TIME: Option = Automatic with Value Time = 0 [s] END TIME DURATION: Option = Total Time Total Time = 6 [s] END TIME STEPS: Option = Timesteps Timesteps = 0.05 [s] END END DOMAIN: Air Coord Frame = Coord 0 Domain Type = Fluid Location = B387 BOUNDARY: Air Inlet Outlet Boundary Type = OPENING Location = F390.387,F388.387 BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 0 [Pa] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END FLUID: Air BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 1 END END END FLUID: Water BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 0 END END END END BOUNDARY: Default Fluid Fluid Interface Side 1 Boundary Type = INTERFACE Location = F389.387 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Default Fluid Solid Interface in Air Side 1 Boundary Type = INTERFACE Location = F391.387,F392.387,F393.387,F394.387,F395.387 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 1.185 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = -9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Air Material = Air Ideal Gas Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: Water Material = Water Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END FLUID: Air FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: Water FLUID BUOYANCY MODEL: Option = Density Difference END END HEAT TRANSFER MODEL: Fluid Temperature = 25 [C] Homogeneous Model = Off Option = Isothermal END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Scalable END END FLUID PAIR: Air | Water INTERPHASE TRANSFER MODEL: Option = None END MASS TRANSFER: Option = None END END INITIALISATION: Option = Automatic FLUID: Air INITIAL CONDITIONS: VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 1 END END END FLUID: Water INITIAL CONDITIONS: VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 0 END END END INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = 0 [Pa] END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END MULTIPHASE MODELS: Homogeneous Model = On FREE SURFACE MODEL: Option = None END END END DOMAIN: Default Domain Coord Frame = Coord 0 Domain Type = Solid Location = B223, B338 BOUNDARY: Default Domain Default Boundary Type = WALL Location = \ F224.223,F225.223,F226.223,F227.223,F228.223,F229. 223,F340.338,F341.33\ 8,F342.338,F343.338,F344.338,F345.338,F348.338,F35 1.338 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END BOUNDARY: Default Fluid Solid Interface in Default Domain Side 2 Boundary Type = INTERFACE Location = \ F230.223,F231.223,F232.223,F233.223,F234.223,F235. 223,F236.223,F237.22\ 3,F238.223,F239.223,F240.223,F241.223,F242.223,F24 3.223,F244.223,F245.\ 223,F246.223,F247.223,F248.223,F249.223,F250.223,F 251.223,F252.223,F25\ 3.223,F339.338,F346.338,F347.338,F349.338,F350.338 ,F352.338 BOUNDARY CONDITIONS: HEAT TRANSFER: Option = Adiabatic END END END DOMAIN MODELS: DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END END INITIALISATION: Option = Automatic INITIAL CONDITIONS: TEMPERATURE: Option = Automatic with Value Temperature = 298 [K] END END END SOLID DEFINITION: Solid 1 Material = Aluminium Option = Material Library MORPHOLOGY: Option = Continuous Solid END END SOLID MODELS: HEAT TRANSFER MODEL: Option = Thermal Energy END THERMAL RADIATION MODEL: Option = None END END END DOMAIN: Water Coord Frame = Coord 0 Domain Type = Fluid Location = B76 BOUNDARY: Default Fluid Fluid Interface Side 2 Boundary Type = INTERFACE Location = F91.76 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = Conservative Interface Flux END TURBULENCE: Option = Conservative Interface Flux END END END BOUNDARY: Default Fluid Solid Interface in Water Side 1 Boundary Type = INTERFACE Location = F78.76,F79.76,F81.76,F82.76 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END BOUNDARY: Inlet Boundary Type = INLET Location = F77.76 BOUNDARY CONDITIONS: FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Cartesian Velocity Components U = Vel U V = Vel V W = 0 [m s^-1] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END FLUID: Air BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 1-WatVF END END END FLUID: Water BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = WatVF END END END END BOUNDARY: Opening Boundary Type = OPENING Location = F80.76 BOUNDARY CONDITIONS: FLOW DIRECTION: Option = Normal to Boundary Condition END FLOW REGIME: Option = Subsonic END MASS AND MOMENTUM: Option = Opening Pressure and Direction Relative Pressure = 0 [Pa] END TURBULENCE: Option = Medium Intensity and Eddy Viscosity Ratio END END FLUID: Air BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 1 END END END FLUID: Water BOUNDARY CONDITIONS: VOLUME FRACTION: Option = Value Volume Fraction = 0 END END END END BOUNDARY: Wall Boundary Type = WALL Location = \ F92.76,F93.76,F94.76,F95.76,F96.76,F97.76,F98.76,F 99.76,F90.76,F89.76,\ F88.76,F87.76,F86.76,F100.76,F83.76,F84.76,F85.76 BOUNDARY CONDITIONS: MASS AND MOMENTUM: Option = No Slip Wall END WALL ROUGHNESS: Option = Smooth Wall END END END DOMAIN MODELS: BUOYANCY MODEL: Buoyancy Reference Density = 1.185 [kg m^-3] Gravity X Component = 0 [m s^-2] Gravity Y Component = -9.81 [m s^-2] Gravity Z Component = 0 [m s^-2] Option = Buoyant BUOYANCY REFERENCE LOCATION: Option = Automatic END END DOMAIN MOTION: Option = Stationary END MESH DEFORMATION: Option = None END REFERENCE PRESSURE: Reference Pressure = 1 [atm] END END FLUID DEFINITION: Air Material = Air Ideal Gas Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID DEFINITION: Water Material = Water Option = Material Library MORPHOLOGY: Option = Continuous Fluid END END FLUID MODELS: COMBUSTION MODEL: Option = None END |
August 9, 2018, 07:05 |
Rep Power: 7 |
FLUID: Air
FLUID BUOYANCY MODEL: Option = Density Difference END END FLUID: Water FLUID BUOYANCY MODEL: Option = Density Difference END END HEAT TRANSFER MODEL: Fluid Temperature = 25 [C] Homogeneous Model = Off Option = Isothermal END THERMAL RADIATION MODEL: Option = None END TURBULENCE MODEL: Option = k epsilon BUOYANCY TURBULENCE: Option = None END END TURBULENT WALL FUNCTIONS: Option = Scalable END END FLUID PAIR: Air | Water INTERPHASE TRANSFER MODEL: Option = None END MASS TRANSFER: Option = None END END INITIALISATION: Option = Automatic FLUID: Air INITIAL CONDITIONS: VOLUME FRACTION: Option = Automatic with Value Volume Fraction = 1-WatVF END END END FLUID: Water INITIAL CONDITIONS: VOLUME FRACTION: Option = Automatic with Value Volume Fraction = WatVF END END END INITIAL CONDITIONS: Velocity Type = Cartesian CARTESIAN VELOCITY COMPONENTS: Option = Automatic with Value U = 0 [m s^-1] V = 0 [m s^-1] W = 0 [m s^-1] END STATIC PRESSURE: Option = Automatic with Value Relative Pressure = HydroP END TURBULENCE INITIAL CONDITIONS: Option = Medium Intensity and Eddy Viscosity Ratio END END END MULTIPHASE MODELS: Homogeneous Model = On FREE SURFACE MODEL: Option = None END END END DOMAIN INTERFACE: Default Fluid Fluid Interface Boundary List1 = Default Fluid Fluid Interface Side 1 Boundary List2 = Default Fluid Fluid Interface Side 2 Interface Type = Fluid Fluid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END MASS AND MOMENTUM: Option = Conservative Interface Flux MOMENTUM INTERFACE MODEL: Option = None END END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = GGI END END DOMAIN INTERFACE: Default Fluid Solid Interface Boundary List1 = Default Fluid Solid Interface in Air Side 1,Default \ Fluid Solid Interface in Water Side 1 Boundary List2 = Default Fluid Solid Interface in Default Domain Side 2 Interface Type = Fluid Solid INTERFACE MODELS: Option = General Connection FRAME CHANGE: Option = None END PITCH CHANGE: Option = None END END MESH CONNECTION: Option = GGI END END OUTPUT CONTROL: RESULTS: File Compression Level = Default Option = Standard END TRANSIENT RESULTS: Transient Results 1 File Compression Level = Default Option = Standard OUTPUT FREQUENCY: Option = Every Timestep END END END SOLVER CONTROL: Turbulence Numerics = First Order ADVECTION SCHEME: Option = High Resolution END CONVERGENCE CONTROL: Maximum Number of Coefficient Loops = 10 Minimum Number of Coefficient Loops = 1 Timescale Control = Coefficient Loops END CONVERGENCE CRITERIA: Residual Target = 1.E-4 Residual Type = RMS END TRANSIENT SCHEME: Option = Second Order Backward Euler TIMESTEP INITIALISATION: Option = Automatic END END END END COMMAND FILE: Version = 19.0 END |
August 9, 2018, 07:14 |
Rep Power: 143 |
I cannot see anything obviously wrong there, it looks like a pretty standard setup.
Try regenerating your def file in CFX-Pre. To speed things up you can import the CCL you just posted so it sets it all up in one go. Maybe you have a def file with some weird form of corruption.
August 9, 2018, 07:34 |
Rep Power: 7 |
May I know how to regenerate the def file? Or it means that I just need to redo the setup?
August 9, 2018, 18:16 |
#9 |
Rep Power: 143 |
Just redo the setup.
August 15, 2018, 12:06 |
#10 |
Rep Power: 32 |
Does it happen at a specific timestep? Can you try writing a transient file every timestep to isolate the state of the model from other things?
For example, writing the file for the initial timestep even before the model is discretized and solved. Use another option for the file, say Essential, or Minimal? If the behavior changes, the file is being corrupted by the writing process of a quantity used in your model. Let us know, and hopefully, we can help. |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 06:45 |
[swak4Foam] installing funkySetFields | igo | OpenFOAM Community Contributions | 1 | November 20, 2012 20:16 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
