February 14, 2002, 10:00 |
CFX-5.5: Meshing subdomain with inflation
Simple geometry: large cylindrical flow volume with volumetric heat source in the first half, that's why I need a subdomain. This subdomain fills the whole volume in the first part of the fluid-domain and the fluid after exiting the subdomain flows on through the rest of the cylinder. I need inflated boundary on all the inner walls of this geometry but Build doesn't make me a def file. (for example if I wan't to use the "Type: Bound Conditions" with "Select Current Walls" option) Most common error message: surface volume is self intersecting
Looking forward to your help Thanks Bogdan |
February 14, 2002, 18:43 |
Re: CFX-5.5: Meshing subdomain with inflation
Bogdan,
Have you tried selecting the surfaces, rather than using the boundary condition option? Give it a try with only a few surfaces first. Sometimes there may be a single surface that is giving you grief, when excluded you can at least get inflation on the rest. Also, have you downloaded the recent patches from ftp site? Robin |
February 15, 2002, 04:27 |
Thanks but for both question my answer is yes... My experience is that the problem is with the subdomain stuff. If I leave some space (very litte is enough) between the end of the subdomain and the inflated part of the rest (so it looks like [inflated subdomain]..[the rest with inflation]) it's ok but it is very ugly...
Help regarding basic airfoil meshing in CFX | amoolraina | ANSYS Meshing & Geometry | 2 | May 22, 2010 18:51 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 12:45 |
CFX Meshing Error! | C Mc Guinness | Main CFD Forum | 0 | April 3, 2005 13:20 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
cfx, meshing + examples | mark | Main CFD Forum | 1 | December 21, 2000 23:10 |
