May 27, 2017, 06:32 |
Pump Simulation
A
Dear,
I did a simulation of a centrifugal pump in CFX, but I used it in SETUP "No Slip Wall" with the "Wall Roughness" option Smooth Wall, my initial purpose was to compare the difference of two materials: nodular cast iron and stainless steel AISI 304 polished, the theoretical roughness values I possess, would be correct in SETUP - Wall Roughness select ROUGH WALL and enter the value? It is the same with the pump diffuser, if it is correct I will compare the two theoretical curves that will be generated. Thanks |
May 27, 2017, 07:14 |
Rep Power: 143 |
Yes, that sounds correct.
Centrifugal Pump Simulation Problem! | warex | FloEFD, FloWorks & FloTHERM | 29 | September 23, 2014 10:27 |
problem for centrifugal pump transient simulation | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | January 15, 2014 04:55 |
URGENT-Simple Oil pump simulation using STAR CCM+ | Race7373 | CFD Freelancers | 5 | October 26, 2013 02:59 |
Peripheral pump CFD simulation | Nevel | Main CFD Forum | 0 | October 8, 2009 01:09 |
Positive displacement pump simulation | jsm | STAR-CCM+ | 0 | October 5, 2009 03:14 |
