March 20, 2002, 12:57 |
topology
I get this error when trying to mesh a solid - ''Topology error detected in CAD model. CAD edge referenced 4 times by faces. Model invalid for meshing.'' Does anyone know what this means? Jennifer |
March 28, 2002, 11:54 |
Re: topology
There is a problem with your domain and subdomain definition. Your probably have two solids in the same domain that touch at an edge. Solids must connect at whole faces. If this is the problem, you can correct it by putting the two solids that touch at an edge in different sub-domains.
Pat |
Topology change and zone modification | WiWo | OpenFOAM | 0 | July 7, 2010 04:35 |
[ICEM] Building topology command script files | Anorky | ANSYS Meshing & Geometry | 8 | January 11, 2010 07:25 |
how to rebuild the geometry topology starting from the mesh. | joegi.geo | ANSYS Meshing & Geometry | 1 | December 1, 2009 23:17 |
ICEM topology | Igor-a | CFX | 0 | July 24, 2008 07:05 |
Topology | SAM | FLUENT | 2 | October 13, 2004 00:01 |
