Postprocessing
Old   April 10, 2002, 11:09
Default Postprocessing
Dimitris
I have a circular cyinder in axial flow and I'm calculating the temp. and heat transfer coeff. on the cylinder walls. After the simulation I export result files with the coordinates, temp, yplus and heat transfer coefficient because I want to plot them, but I only want to plot from the middle of the cylinder front, across the circumference to the middle of the backside of the cylinder, so I need values in a straight line. Until now I've been using matlab so I can sort the different nodes and interpolating them in a straight line but I wonder if CFX post can give me the results right away in a straight line or if CFX post itself can make a graph with what I want!!! Any ideas or suggestions anyone?
Old   April 10, 2002, 16:49
Default Re: Postprocessing
Astrid
Define a text file containing:
- the number of points
- the x y z -coordinates
For example:
4
1 1 1
2 1 1
3 1 1
4 1 1
Read in the polyline.
Export the variables you want on the polyline.
The polyline does not have to be a line. It can be just a bunch of random numbers.
Astrid
Old   April 10, 2002, 18:03
Dimitris
Well....I don't want to seem too stupid but I didn't quite follow you...can you perhaps explain one more time?
Old   April 10, 2002, 22:06
Robin
Hi Dimitris,
Create a Plane in Post which cuts through your cylinder. Then create a Polyline by intersecting the cylinder boundary and the plane. You can then create a graph using the polyline you have created and the variable you wish to plot. Alternatively, you could export the data from the polyline to a file and plot it in the application of your choice.
Robin
Old   April 11, 2002, 08:45
cfd guy
You're not the first one with this kind of problem. You might take a look at this link:
http://www.cfd-online.com/Forum/cfx_....cgi?read=1838
This topic was already explored.
cfd guy
using fieldAverage library to average postprocessing eelcovv OpenFOAM Programming & Development 32 May 17, 2022 09:55
How to export the specific heat and viscosity for postprocessing (compressible) ? david39 OpenFOAM Post-Processing 2 January 4, 2019 07:04
[pythonFlu] Postprocessing using pythonFlu + Matplotlib +Scipy francois OpenFOAM Community Contributions 2 June 21, 2011 11:26
Question about Postprocessing Using UDF(in tutoria sarah_ron2002 FLUENT 1 April 10, 2007 16:17
postprocessing bas rijkse FLUENT 0 July 5, 2001 08:30
