April 5, 2002, 12:40 |
Saving data from monitoring points
Hi all,
I have added several monitoring points in my CFX-5.5 simlation. I can view the variables in the points during the iteration process. Very nice. Now I would like to save the data to make some Excel-graphics. How can I do this? During the iteration process a temp file is created called 'mon' with the data but it seems to disappear completely when the run has finished. Can it be retrieved? Thank you for reading, Astrid |
April 6, 2002, 00:36 |
Re: Saving data from monitoring points
The mon file gets stuck back into the results file when the run finishes. I think that there is a command line tool for extracting it, but the name of it escapes me at the moment. Maybe you can just check through the different commands in the CFX-5.5 bin directory.
Neale. |
April 7, 2002, 18:01 |
cfx5dfile -read-monitor file.res >file.mon
April 10, 2002, 05:55 |
Steve,
That works fine. Thank you. Astrid |
Display Modes | |
fluent udf, saving data in udf | mohsen zendehbad | Fluent UDF and Scheme Programming | 15 | June 14, 2017 00:23 |
Problem in running ICEM grid in Openfoam | Tarak | OpenFOAM | 6 | September 9, 2011 18:51 |
Arclength parameterization of a curve whose data points known | ipp | Main CFD Forum | 1 | July 11, 2011 15:13 |
Saving of monitor points in batch mode. | Martijn | CFX | 3 | December 10, 2008 11:36 |
Can you post a blade data points file example??? | Nicola | Fidelity CFD | 0 | September 21, 2007 12:38 |
