June 16, 2017, 05:43 |
Solver manager
Mahesh Chamarti
Rep Power: 9 |
The solver manager finished very quickly without generating any results. can anyone suggest what could be wrong. i am trying to run a steady simulaiton on a radial turbocharger
June 16, 2017, 07:02 |
Rep Power: 143 |
Read the output (the text file in the right window). It will tell you if the simulation completed and why it completed. The dialog box does not give much information.
June 16, 2017, 07:14 |
#3 | |
Mahesh Chamarti
Rep Power: 9 |
The simulaiton takes less than 10 sec and there are no warnings or errors. It is a big domain with 7 million cells so it should take longer. moreover the result file is not written. i have encountered such a problem. kindly give your opinion. |
June 16, 2017, 07:30 |
Rep Power: 143 |
My opinion is that you should read the output file because that is where it tells you why the run was determined to have completed. All the details of what happened are in the output file.
June 17, 2017, 11:47 |
Rep Power: 16 |
Have you started a partition-only run by mistake?
-max-, ac1993, ahmed425, ahmettgultekin, alaabejaoui |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
Wall and Boundary Scale - CFX Solver Manager | MissCFD | CFX | 1 | October 24, 2016 01:25 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
