Particle temperature setting with heat source routine |
June 24, 2017, 12:24 |
Michael Emter
Rep Power: 9 |
i am using the fortran file heatsource.F to set the temperature of my particle (Inlet) which is flying through a fluid with a certain temperature. Under Default Domain->Fluid Pair Models->Heat Transfer Option-> Particle User Source i can link the fortran file with my model. In the heat source file you have a equation SOURCE = FACT*(TEMP_FL-TEMP_PT) Now replacing TEMP_PT with a value like 500, then you have an equation SOURCE = FACT*(TEMP_FL-500)) So the Particle temperature in the next time step should be set up to 500 K. But in my simulation the particle temperature dont get 500 K. What could be the reason for that? How would you manipulate the particle temperature in fortran? Best regards |
cfx, fortran, heat source, heatsource |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
