Additional variables in CFX5
Old   May 13, 2002, 08:57
Default Additional variables in CFX5
Cath Noakes
I'm modelling a room air flow with an additional variable to represent contaminants in the room. I need to know the concentration of the contaminant at the outlets (in kg/m3) to use as the inlet conditions for another domain. Does anyone know the correct CEL expression to find this value? I found the mass flow rate for the air as a whole using the expression
massFlow()@exhaust but when I tried a similar expression to find the contaminant mass flow,
massFlAve(contaminant)@exhaust I got solver errors. I am using CFX 5.5
Thanks in advance for any help
Cath
Old   May 13, 2002, 10:18
Default Re: Additional variables in CFX5
Robin
Hi Cath,
Assuming it was not a typo, the correct command should be:
massFlowAve(contaminant)@exhaust not massFlAve(...)
If this is not the problem, read the error message carefully (by the way, it would be a Post error message, not solver). Also, be aware that expressions are case sensitive, so if it is Contaminant, and not contaminant, you will get an error.
Regards, Robin
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
additional variables' effect ariel CFX 9 April 2, 2008 00:41
user SUBROUTINE for additional variables Tuks CFX 0 November 8, 2005 02:09
Q on additional variables in CFX5 bobbob CFX 0 April 29, 2003 09:25
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
