CFX 10.0 If command
Like Tree2Likes
  • 1 Post By ghorrocks
Old   July 5, 2017, 20:17
Default CFX 10.0 If command
Fernando
camposrf is on a distinguished road
I am trying to make a conditional expression with "if" command in CFX-10.0
I read these articles:
Conditional Expression in CFX Pre
"if" command in CFX-13 is not really an "if" command!!!!
But I do not know how to do it in CFX pre 10.0
I saw in youtube that "if" expression works on CFX 14, but I do not have it (my PC is old)
https://www.youtube.com/watch?v=GJXQNhmqyhE
(11:25)
The string that I want to use is for define the volume fraction in a water tank:
WaterVolFrac =if(y<WaterHt,1,0)*if(y>-0.1[ft],1,0)
This is the error message:
__________________________________________
ERROR
Error in setting: "WaterVolFrac" via the expression:
Error found at the start of the line, at item: if
unrecognised name
I read the _CFXTutorial.book.pdf, Tutorial_FreeSurfaceBump.pdf but they don't use the if command, they use this string:
DownVFAir = step((y-DownH)/1[m])
camposrf is offline   Reply With Quote
Old   July 6, 2017, 06:32
ghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the roughghorrocks is a jewel in the rough
The if statement was introduced in a "recent" version of CFX. Not sure which one, maybe CFX 12, but it looks like CFX 10 did not have it. Sounds like a good time to upgrade to the current version of CFX to me.
Old   July 7, 2017, 16:42
Default CFX-Pre 10.0 "if and step" command
Fernando
I just adapted the original string to my case "WaterVolFrac =if(y<WaterHt,1,0)*if(y>-0.1[ft],1,0)". The function plot works and makes sense.
But I still do not knowing how "the step commad" works. On the other hand, the results in the post environment says that the tank is full of water until the top!...
I was waiting something like this:
Old   July 9, 2017, 08:03
The step command is very simple, and is explained in the documentation (CFX Reference manual). If the argument is positive, it returns +1, if negative it returns 0, if exactly zero it returns 0.5.
camposrf likes this.
Old   August 9, 2017, 16:15
Fernando
Originally Posted by ghorrocks View Post
(...) If the argument is positive, it returns +1, if negative it returns 0, if exactly zero it returns 0.5. (...)
Thx ghorrocks,
Your comment was very useful, now I can adapt this string for make a synthetic "if" command if "step" returns +1 0 or 0.5
The problem with my simulation was not the step command. The mistake was in the vertical definition (Expressions: UpH, UpVFair) as you can see in my second comment in this post; the vertical variable was "Y" but the correct one is "Z".
Here you can see the results with the corrections applied.
Water Volume Fraction profile:
Water Volume fraction surface
Water Volume Fraction profile and surface:
Last edited by camposrf; August 9, 2017 at 16:33. Reason: wrong "preview" clicking
Old   August 9, 2017, 18:23
Please do not post multiple versions of the same post on different threads.
Your surface looks very lumpy and rough. I assume it is not meant to be like this.
* You probably have too coarse a mesh. Have you done a mesh sensitivity study?
* For the initial condition you should blur the free surface over a small distance so irregularities in the mesh do not distort the surface. Have a look in the CFX documentation under best practices guide for multiphase for tips on this.
Old   August 9, 2017, 21:32
Default mesh sensitivity study FAQ
Fernando
Please do not post multiple versions of the same post on different threads.(...)
I do not want to do that, I was just trying to help
Originally Posted by camposrf View Post
Originally Posted by glik View Post
(...) I have a problem with the interface when I had a horizontal acceleration to simulate the seism. (...)
I had the same issue with the interface. I defined the volume fraction (...)
(...) Your surface looks very lumpy and rough. I assume it is not meant to be like this. (...)
Yes, you are right.
(...)* You probably have too coarse a mesh. (...)
Yes, right again, it is a coarsed one. I have to do approximation cases first before run a detailed model “if I want the results this year” (joke). Further more, it has a worst residuals convergence (0.01). The good news is that the time step is ok because it is a steady simulation.
I have to do this previous work because I do not have a powerful PC. I accept donations (is not a joke).
(...) Have you done a mesh sensitivity study? (...)
No, I have not done. I think that my PC can not handle that. I do not know how I can do that. I did not find the FAQ with the instructions.
(...) Anyone - we really need to write a FAQ on the basics of checking mesh, timestep and residuals convergence and sensitivity for these type of basic questions. 90% of the "my simulation is not accurate" questions do not do the basics here - any takers?
(...)* For the initial condition you should blur the free surface over a small distance so irregularities in the mesh do not distort the surface. Have a look in the CFX documentation under best practices guide for multiphase for tips on this.
Thanks for your comment, I will check it.
Old   August 9, 2017, 21:46
Default the mesh of the tank
Fernando
This is the mesh that I used, is not a detailed one but works for preliminary runs.
Old   August 12, 2017, 23:26
Default Grid and error analysis FAQ
Fernando
(...) I did not find the FAQ with the instructions. (...)
Finally I found the FAQ, but searching from an external search engine.
There is an FAQ about linear solver overflow now: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
https://www.cfd-online.com/Wiki/Ansy..._inaccurate.3F
launch cfx from command line question windhair CFX 3 May 19, 2011 07:16
Export CGNS with CFX 10.0 Luca CFX 1 December 29, 2010 06:09
Low Reynolds Number k-epsilon formulation CFX 10.0 Chris CFX 4 December 7, 2009 23:51
How to red a Gambit mesh with Ansys CFX 10.0 jpsegura CFX 5 June 12, 2007 02:20
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
