a grid error during solving process
Old   June 9, 2002, 23:56
Default a grid error during solving process
Tiefeng WANG
Hi everyone:
The problem is about the simulation of a external-loop airlift reactor. I have obtained the geo file by build. But a error occurs when reading the grid in solving process. The error massege is like this: ERROR SPECIFYING GRID IN BLOCK BLOCK-NUMBER-1 THE CELL VOLUME CHANGES SIGN THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 1, 1, 1) THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 6, 4, 15) THE VOLUME CHANGES SIGN AT CONTROL VOLUME ( 8, 4, 15)
MAXIMUM VOLUME = 0.4969E-12 MINIMUM VOLUME = -.9555E-04 ***> ERROR NUMBER 1 IN FRONTEND PROCESSING
Could you tell me how can i correct this error? Thanks a lot in advance.
Old   June 11, 2002, 16:54
Default Re: a grid error during solving process
Astrid
It looks like you have somewhere elements with negative volumes. Try to read the geometry in Analyse or Visualise (or View) to find out where your elements do not match the geometry. Then create a new geometry in Build.
Astrid
Old   June 14, 2002, 09:07
James Date
I think you might have picked the points on Block no. 1 in the wrong order when you made it. Make sure you pick them in an orderly fashion face by face. All the best.
James
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Full pipe 3D using icoFoam cyberbrain OpenFOAM 4 March 16, 2011 09:20
Computational time sunnysun OpenFOAM Running, Solving & CFD 5 March 16, 2009 03:32
