July 12, 2017, 15:29 |
error due to isolated region
yaseen
Rep Power: 10 |
I want to simulate flow over the weir, the fluid domain consists three parts, at the beginning the solver show error, this is due to isolated region between parts, How can I solve solve this problem.
note: I know by making the domain into one solid part this problem can be overcome, but this way is not good for applying different mesh size. |
July 12, 2017, 17:41 |
Rep Power: 32 |
An isolated region is a symptom of an incorrect set of boundary conditions. It seems you got a volume that is not connected to the other two.
July 13, 2017, 02:03 |
yaseen
Rep Power: 10 |
Thanks for your reply
As I understood from you, you want to say that there is space between two parts, (during geometry creation) |
July 13, 2017, 06:28 |
Rep Power: 143 |
Either there is a gap between the parts or you did not join the parts together. They can be joined together a number of ways:
* The mesh can be made contiguous, this is done in the mesher and no solver interface is required. * If the mesh matches 1:1 then use a 1:1 interface. * If the mesh does not match then use a GGI interface. |
July 14, 2017, 06:57 |
yaseen
Rep Power: 10 |
thanks a lot Glenn for your reply
just, the second solution what do you mean by 1:1 interface? how can be done? I use ANSYS ICEM for meshing |
July 14, 2017, 07:06 |
Rep Power: 143 |
A 1:1 interface requires the mesh matches perfectly at the interface, but they are separate mesh regions. Then in CFX pre you join them with a 1:1 interface.
July 19, 2017, 06:49 |
#7 | |
yaseen
Rep Power: 10 |
https://www.cfd-online.com/Forums/at...1&d=1500461260 https://www.cfd-online.com/Forums/at...1&d=1500461284 |
July 19, 2017, 07:21 |
Rep Power: 143 |
The mesh is not necessarily joined even if there is no gap. You need to put interfaces into connect the mesh bodies, as I stated in post #4.
July 20, 2017, 06:38 |
#9 |
yaseen
Rep Power: 10 |
[QUOTE=ghorrocks;657609] yes, thanks for your reply I understood
[mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 18:57 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 04:38 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
