CEL in CFD-Post - Combining Parameter with String
i am new in writing Macros for CFD-Post that's why I have some problems. My problem is that I want to combine a Paramter with a String. Thats my Code: # Macro GUI begin # # macro name = TestMakro # macro subroutine = mySub # # macro parameter = Version-Number # type = integer # # macro parameter = VelAngle # type = float # # Macro GUI end ! no warnings 'redefine'; ! sub mySub { ! ($datanr, $angle) = @_; >load filename=/home/XXX/YYY/CFD/$datanr/'$datanr'Version-transient.dat, force_reload=\ true For example my file-name is 83Version-transient.dat and i want to load this result file with this macro. How can I achieve that ? The '83' will be declared as a parameter and i want to use it. What i get is '83'Version-transient.dat with the code above and that can't be loaded. Thanks |
try adding a variable for the filename location, say
! myfile = /home/XXX.... > load filename = myfile , .... Then, it is all about Perl string concatenation rules. |
Sorry for the late reply. It worked. Thank you.
