y+ contour plot through flow domain
I was trying to create a contour plot of the yplus value at an arbitrary plane throuh my flow domain. Therefore what I did is creating the according plane, then creating a contour plot with the beforehand created plane as the location and Yplus as the variable with local/global range. If I choose any other variable than Yplus - like pressure, density, ... - I see the expected contour plot. Once I pick Yplus the plane/contour simply disappears, whereas I do see the legend with the a value range. (0 to 1.88) I have naturally checked for tutorials but couldnīt find any fault in my procedure also since it is a pretty basic problem as far as i can tell. worth mentioning: It is also possible to color a plane directly using a certain variable. This methods results in CFX displaying the according plane in grey colour except very close to the walls which are coloured. I appreciate any hints regarding this. Regards, katha |
Hi
This was a topic meny times here on the forum, so you could search it. And this is a comon but simple problem to people geting into cfd. Y+ value only aplies to walls there is no y+ value further from the wals so everithing is grey (no value) but you see values in the first element from the wall this is vhere y+ is relevant and imortant. So only first element from the wall is coloured. |
Yes, this question has been asked a few times. Can you add it to the FAQ page? https://www.cfd-online.com/Wiki/Ansys_FAQ
hi,
thx for the answers, well I dont know, why I didnt find it. Of course I know, that y+ is a value only relevant to the wall, nevertheless I have used other software before and therefore know, that it is possibly to create such a contour plot in fluent for example. The reason I was trying to plot it is since I thought it could be useful in optimizing the mesh as it could reduce the number of iterations by knowing that for example my third layer had a ceratin y+ that I desire. Anyways thank u for the quick reply. |
If you draw contours of the wall boundary objects rather than the cross section plane you will get a useful plot. I think that is what you are trying to do. You can do this as y+ exists everywhere on a wall boundary, of course.
ja, that was the first thing I did of course. As I said my aim was to reduce the amount of times I would have to change the mesh (which is rather large therefore grid generation takes time) by seeing how the y+ looks like in the third/fourth layer and then estimating the according cell height.
