[Sponsors] | |||||
Arvind
Rep Power: 11 ![]() |
I am trying to run CFX from another software and using a batch file like this:
"C:\Program Files\......\cfx5solve.exe" -batch -def part1.def -name part1 -s 1 I am fixing the parallel run and double precision in cfx file from simulation control option. But my problem is every time i need to click the run option in cfx . what i need to change in batch file to make the system automatic without the requirement to click run manually? |
Rep Power: 146 ![]() ![]() ![]() ![]() |
Have a look in the documentation under the section "Running from the Command Line".
In your example command line, I suspect you don't need the -batch, -name and the -s options, it should just be "<PATH>\cfx5solve -def part1.def" |
Arvind
I tried with your suggestion, but still it's the same, i have to start the solver manually. Please see the attached picture.I have to click on the start run option to start the solver. My question is what command should i use to make this thing automatic. |
The best way is to fire up a command line from the CFX Launcher (Tools/Command Line) as that automatically includes the path to all the CFX executables in it. Then type cfx5slove -def YourFile.def and it will go.
I don't know why you posted an image of Solver Manager, you don't use it when you run from the command line. |
Arvind
@ghorrocks
Thank you for your suggestions and what you told is working. Probably i did not explain my problem properly. I am trying to create an automatic optimization loop, where icem, cfxpre and cfx solver will run in a manner without human intervention.I am able to do that with icem and cfxpre, but i am stuck with cfx solver. So every time i am running the batch file,the cfx solver manager pops up and i need to click 'start run' to start the solver. That's why i attached the picture. I am attaching .bat file, its in text format. Any help in this regard will be highly appreciated. |
Have you tried using the "cfx5solve -def part1.def" as I suggested in post #2? I never get the solver manager popping up and I use the command line frequently - but I never use the -batch option.
Also: Workbench has optimisation built in across the ANSYS suite. You can pass variables around as parameters. Have you considered doing your optimisation in workbench? |
Arvind
Yes, i tried whatever you told. Solver manager is not popping up if i use command line from cfx launcher as you told in post#3.
But as you told in post #2, without using batch file, it's still the same. I have no clue why it is happening. I know optimization is possible through workbench, but there is some particular reason why i am trying this. So i must make it run automatically, but i am kind of stuck now. |
Maxim
Rep Power: 14 ![]() |
maybe you could just post here the complete command that you use and we look for your mistake? I think most of us use commend line and it is pretty straight forward if you just followed the manual...
edit: mine looks like this: Code:
"C:\Program Files\ANSYS Inc\v181\CFX\bin\cfx5solve.exe" -batch -double -par-local -part 8 -def P1070_317rpm_832L_B0.def -ini-file P1070_317rpm_832L_B0_FR_001.res -pri 1 -size-nr 1.2x -size-ni 1.2x Last edited by -Maxim-; August 1, 2017 at 05:37. Reason: example command |
#9 |
Arvind
Thanks to all, apparently i found out the problem and solution.
It was the problem with batch file for cfx pre,there it was mentioned to start cfx solver interactively. |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Monitoring in batch mode | jmjohansen | ANSYS | 0 | July 1, 2015 13:48 |
| [PyFoam] having problems with pyfoam Installation | vitorspadetoventurin | OpenFOAM Community Contributions | 3 | December 2, 2014 08:18 |
| [ICEM] ICEM CFD error when running in batch mode | bgp723 | ANSYS Meshing & Geometry | 0 | August 14, 2014 14:45 |
| [ANSYS Meshing] Automatic mesh generation by batch file | nealrm | ANSYS Meshing & Geometry | 5 | April 1, 2014 19:59 |
| [ICEM] Can it make extruded 2D meshes for 2D CFX simulations? | siw | ANSYS Meshing & Geometry | 10 | October 23, 2009 09:47 |
