[Sponsors] | |||||
behrouz
Rep Power: 12 ![]() |
hi to all
im try to simulate two parallel plate with small distance between them(distance=3 mm) as picture, upper plate have a Rectangular groove(T shape) on it,and move in teta-direction with 30 m/s speed(Ur=Uz=0 m/s).air inter form top and exit from bottom, boundary condition: inlet total pressure=60 bar exit static pressure=2 bar upper wall=no slip wall and teta-direction velocity=30 m/s (Ur=Uz=0) other wall= no slip stationary wall and rotational periodicity for left and right wall( walls are infinite in teta-direction) mesh quality is pretty good and max skewness=0.8 and average skewness=0.15 and flow is laminar, isothermal, ideal gas but.....!! when i start the solver ,some error occurred(pic 2) and solver stop, i try change local time scale,automatic time scale,physical time scale but error happen again, any idea,suggest,reference,would be nice thank you very much. Last edited by behrouz; August 2, 2017 at 02:01. |
Erik
Rep Power: 24 ![]() |
Translational periodicity???
Z direction??? Don't you need rotational periodicity and a cylindrical coordinate system? |
behrouz
ok...........
#4 | |
behrouz
thank you for your atention yes you right and i correct the coordinate system and rotational periodicity in my explain,in fact i use cylindrical coordinate and rotational periodicity and errors happen, so please have you any idea about it?? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 17:49 |
| HELP! Flow over both sides of a plate. | farocean97 | Main CFD Forum | 0 | September 12, 2011 11:57 |
| heat transfer on dimpled plate | mech | FLUENT | 4 | February 6, 2007 16:15 |
| free convection between 2 infinite parallel plate | runny craven | Main CFD Forum | 2 | September 19, 2001 06:45 |
| Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 13:00 |
