similar result using SST and k-e turbulence model |
August 1, 2017, 14:25 |
yaseen
Rep Power: 10 |
Hello every one
I simulated flown over the weir using SST and k-e turbulence model but both results are similar (inlet and outlet mass flow rate. and wall function, is a straight line. Is that possible. Regards https://www.cfd-online.com/Forums/at...1&d=1501611800 https://www.cfd-online.com/Forums/at...1&d=1501611819 https://www.cfd-online.com/Forums/at...1&d=1501611844 |
August 1, 2017, 19:38 |
Rep Power: 143 |
Yes, this is possible, in fact it is normal. CFX uses an iterative approach to work out the wall distance and it usually converges after a few iterations, and much quicker than the CFD solver. So it frequently looks like what you show.
August 2, 2017, 04:18 |
#3 | |
yaseen
Rep Power: 10 |
Also I used RNG k-e, but after 800 iteration it doesnot reach convergence, and its accuracy is less than k-e and SST, while SST and k-e after 150 or less iterations reach the convergence, can you tell me the reason. Regards |
August 2, 2017, 06:36 |
Rep Power: 143 |
RNG is very similar to k-e, but has subtle differences. Have a look at the CFX documentation or a turbulence textbook for more details.
It looks like in your case the subtle differences are enough to make it not converge. But remember for other cases it works better, so it will depend on exactly what you are modelling to determine the best turbulence model. |
August 2, 2017, 11:57 |
#5 | |
yaseen
Rep Power: 10 |
I am modelling of flow of water over weir like flow over bump but the difference is in my case jump was occur when the water reach downstream of the weir. Yes this is my job, to find a turbullence that can well simulate all flow variables, k-e worked for fully turbullent flow, but near walls flow is almost laminar, and at the jump there is swirling for this reason I want to use RNG Regards |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
General question about SST turbulence model | Richard Renaud | CFD Freelancers | 1 | December 19, 2015 04:13 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
