[Sponsors] | |||||
Interfaces between two regions in rotor's simulation |
Nate Lau
Rep Power: 11 ![]() |
Dear all,
I want to check the foam bulk effect on the flow filed around rotor tip. The sketch is in the attachment: foam bulk is attached on the casing inner wall (full coverage) and it stays stationary while both rotor and hub rotates. I am wonder if I give a right setting on the interfaces between foam area and main channel. As showed in another picture in attachment, I define the interface as 'Frozen rotor' type and no operation is given on 'Rotational Offset' and 'Pitch Change'. Then in terms of Domain Motion of Foam area, 'Stationary' is selected and 'Rotating' with a fixed speed is for the Main Channel. Both Blade and Hub is set to be rotating and the new shroud (named 'wall1' in the schematic) is set to be wall with no velocity. The result is converge but I am not sure about my set since I am quite new to CFX and I feel a little dizzy about the frame of reference in CFX... I try some other settings and they all give me bad feedback. Would anyone give me an answer? |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| CFD simulation of gas cicrcuit breaker in fluent with dynamic meshing. | Mahesh7238 | FLUENT | 1 | April 5, 2021 01:21 |
| Adding heat source to chtMultiRegionFoam | maddalena | OpenFOAM Programming & Development | 61 | February 17, 2018 09:33 |
| restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 11:15 |
| Use homogeneous results as the initial guess for an inhomogeneous simulation | JuPa | CFX | 5 | December 26, 2014 14:44 |
| 3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
