1.5 Stage compressor Problem
2 Attachment(s)
Hello there,
I was trying to simulate a 1.5 compressor stage in CFX. The geometry is very easy and the mesh is generated with TurboGrid. I simulated it in steady state (maybe wrong because of the interaction between Rotor and stator, right?) In the attached screenshots you can see the setup with the interfaces and then the results with streamlines. This looks like the interface from Stator1 to Rotor1 is wrong. I also changed the interface mode between Stage and frozen rotor. The results are nearly the same. Can someone give me a hint, what could solve this? Did I choose wrong interfaces ? Thank you for your help!!! Have a nice day! |
It does not look converged to me. You need to run it longer and converge it more.
Thanks for the quick respond! |
The residuals are the usual guide for how well converged it is. You want it to converge to your residual criteria, which should probably be something like 1e-5.
2 Attachment(s)
so 500 iterations are over. I attached the residuals and the streamline view.
The RMS curves don't look good, too in my opinion. Is it possible that the angular velocity isn't optimal (torque R1= -92Nm) and that these Streamlines occur from this ? |
You convergence never got to 1e-4, so it is highly likely it is not converged. See the FAQ: https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Note that if you are simulating a point off the designed operating point of the device you will get massive separations and complex flow patterns. It will also be very difficult to converge. So make sure that you are simulating the correct operating point before you fiddle with the convergence parameters. |
Thank you for your advice !
I was so concentrated on the RMS P Mass that i didn't notice that the other didn't reach 1e-4. Is it possible to find the operating point through many simulations with parameters? Is there a variable like the zero net torque for turbines to find the operating point ? Thank you for your time ! |
You can find the operating point by simulation but that is the slow way. The best way is to ask the person who designed it.... (or look at their data sheets). Failing that you can estimate the speed by looking at blade angles and the fluid velocity.
But the best way forward depends on what you are trying to do. What are you trying to do? Why are you doing the simulation? |
Okay than I will start from zero with designing it with a purpose and with calculations.
There is no particular reason. I did the simulation just for me to keep the "workflow" in mind. So the design of the blades was very random I didn't even choose a specific profile type. But thats what I'm doing next to achieve a better result. Hope your not mad that these questions were not for a bigger project or so :) Thank you ! |
No, I am glad that you are learning by trying things out. Hopefully you have learn a lot so next time you do it you can do it better.
So make sure the next design is operating at a point where you expect the flow to be fully attached. The operating point will be near there, and the simulation will be much easier to complete properly. |
Yes, definetly!
I will try my best to implement your tips to achieve good reulst! Thank you very much :) |
