Heat transfer with SST
Old   November 8, 2002, 03:18
Default Heat transfer with SST
Eva
HI!
I´m using the SST model in CFX 5.5 to predict heat transfer from an impinging jet on a cylinder. When I´m using a grid with a y+ of 0-12 I get good result (compared to similar cases in the literature), but now I have refined the grid near the surface so I have a y+ of 0-1, then I don´t get the same result. I get a very increased rate of heat transfer on a spot on the side of the cylinder that I believe should not be there. Does anyone else have the same or related problem?
/Eva
Old   November 11, 2002, 18:01
Default Re: Heat transfer with SST
Astrid
- Do you compare with measurements or simulations in literature?
- Which wall function do you use?
- What do you mean by 'the side of the cylinder'?
- Are you sure transient phenomena like vortex shedding do not occur? This will influence you heat transfer....
/Astrid
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
Huge Wall Heat Transfer Coefficients with SST Mode Marco Müller CFX 3 December 19, 2008 07:55
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
