Moving grid (USRGRD) example?
Old   November 7, 2002, 05:47
Default Moving grid (USRGRD) example?
Novak Elliott
Hello, I am looking to model squeeze flow in the bearing gap of a thrust bearing that is moving with simple harmonic motion using CFX (4 or 5). The fluid domain needs to be resized at each timestep. I understand this is called a 'moving grid' problem and requires the use of the USRGRD user routine.
I am having trouble getting started as I cannot find any examples to understand how this sort of model is set up and solved. Are moving grid problems a black art?
Can anyone point me in the right direction? All responses are greatly appreciated.
cheers, Novak.
Old   November 7, 2002, 07:33
Default Re: Moving grid (USRGRD) example?
cfd guy
Hi Novak,
Once I've worked with moving grids in CFX-4. I can say that you can move your nodes using algebraic functions in conjunction with IF Statements in your subroutine. I can send you what I did in the past. Regarding moving grids in CFX-5 I don't know how to proceed or if it's already implemented.
Regards, cfd guy
Old   November 7, 2002, 18:09
Hi Novak,
I will email you a copy of the user fortran code I used to do transient grids in modelling internal combustion engine flows.
My code works (in CFX 4.3) by reading in the CFX geometry file (m01.geo by default), applying a transformation to the original points locations to give new point locations (the tranformation can be a function of time, space or anything) and then uses the new points as the grid for the next time step.
Glenn
who have the education codes for moving grid? aiya Main CFD Forum 0 August 14, 2006 09:53
modification of fractional step for moving grid Wei Main CFD Forum 3 May 13, 2006 21:30
Grid Moving Karthik Krishna FLUENT 4 February 23, 2005 07:57
GRID TO GRID INTERPOLATION in FLUENT calogero FLUENT 3 June 4, 2003 08:32
Unstructured moving grid M.A.Leschziner Main CFD Forum 0 July 15, 1999 07:25
