CFX-Post batch run error
Old   November 13, 2002, 04:44
Default CFX-Post batch run error
KG
Dear CFX-5 users,
My CFX-POst in GUI mode work fine but when I try to run CFX-Post in batch mode with
cfxpost.bat –batch NAME.cse
following message in DOS console appear:
Can't locate Carp.pm in @INC (@INC contains: C:\cfx\CFX-5.5\cfxpost\5.5\\lib\ccl parser \CYGWIN32_NT\perl\lib \CYGWIN32_NT\perl\lib\MSWin32-x86 C:\cfx\CFX-5.5\cf xpost\5.5\lib\perlTools C:\cfx\CFX-5.5\cfxpost\5.5\lib\winnt C:\cfx\CFX-5.5\cfxp ost\5.5\lib\perlLib\WindowsNT .) at C:\cfx\CFX-5.5\cfxpost\5.5\\lib\cclparser/CC L/Utils.pm line 7. BEGIN failed--compilation aborted at C:\cfx\CFX-5.5\cfxpost\5.5\\lib\cclparser/C CL/Utils.pm line 7. BEGIN failed--compilation aborted at C:\cfx\CFX-5.5\cfxpost\5.5\\lib\cclparser/C CL/embeddedParserInit.pl line 1. CCL parser failed with message: Error: Cannot parse perl code
Any advice will be very helpful to me. Thanks in advance.
Best Regards,
KG
Old   November 13, 2002, 08:38
Default Re: CFX-Post batch run error
Robin
Try running Post with the command cfx5post instead of cfxpost.bat.
Robin
Old   November 13, 2002, 08:53
KG
Thanks Robin for your help. It's working.
This is something completely different than CFX-Post user guide instruction. Thank you again.
Best Regards, KG
Old   November 14, 2002, 02:26
Holidays
I have just looked into the on-line manual (P;228 actually) and I cannot fault what Robin said. It IS written: cfx5post -batch myfile.cse myfile.res. The documentation is correct.
Old   November 14, 2002, 04:33
KG
Hi Holidays,
This is from my manual "line_interface_mode.pdf" p.230
To run in Batch mode:
Windows: Execute the command
"CFX-PostROOT\cfxpost.bat -batch filename.cse" at the DOS command prompt.
UNIX: Execute the command
"CFX-PostROOT/cfxpost -batch filename.cse" at the command prompt.
Are we have/reading the same manual?
Best Regards,
KG
Old   November 14, 2002, 08:29
Robin
KG - CFX-5.5 manual Holidays - CFX-5.5.1
Old   November 14, 2002, 09:13
KG
Thanks Robin for make me inform about CFX products.
How can I get CFX-5.5.1? From CFX-community site?
Best Regards,
KG
Old   November 14, 2002, 13:23
Robin
If you have a current license, you should have received 5.5.1 last summer.
Robin
Old   November 15, 2002, 02:23
Holidays
Sorry I assumed we were taking 5.5.1 which is the current version until 5.6Beta
Old   November 15, 2002, 20:23
Neale
Are you expecting to get a copy of 5.6beta?
Old   November 16, 2002, 08:08
  #11
KG
Dear Neale,
Yes I would like to get a copy of 5.6beta? Is it possible?
Thanks,
KG
Old   November 16, 2002, 19:16
  #12
Neale
Well you might ask your service rep and see if you can get on the beta tester list. However, this has certain implications on your time. i.e., you must provide feedback for example.
Neale.
Old   November 18, 2002, 20:02
  #13
Robin
All,
There is a form on the CFX-5 page of the community site which you can fill out to be added to the beta program.
http://www.software.aeat.com/cfxcomm...-5/default.asp
Robin
Old   November 20, 2002, 03:56
  #14
KG
Sorry Robin, I don't have CFX-Community acount.
Regards,
KG
Old   November 21, 2002, 09:51
  #15
Neale
Any current client can get one, ask your service rep, or just go to the website www.cfx.aeat.com and attempt to log into the community site, if you have no username and password it forwards you to a form so you can get one.
Neale
Old   November 21, 2002, 09:52
  #16
Neale
Here is the link:
http://www.software.aeat.com/cfx/community/apply.htm
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
