September 29, 2017, 15:54 |
Pressure solved by CFX & Total pressure
Rep Power: 11 |
In my CFX model (see the simplified picture attached), I impose a velocity at inlet (section 1) and a relative static pressure at outlet (section 2). For example: = 5 m/s & = 0 Pa Physically, the net head is equal to: = ++g - (++g) In CFX, when I do the difference of total pressure between the two sections: massFlowAve(Total Pressure)@inlet - massFlowAve(Total Pressure)@outlet for me, CFX do this calculation: + - (+), so the term of the potential energy (g) is not taken into account, it that perception right ? Or maybe, the pressure solved by CFD takes into account this term ? Or should I use the absolute pressure to obtain the exact value ? Can someone explain me this point ? What does correspond exactly the pressure solved by CFX in this case ? Thank you for you help ! |
October 2, 2017, 08:24 |
Rep Power: 32 |
Not certain, but did you activate buoyancy? That is the only known mechanism to include gravity into the equations.
You should be able to verify if the elevation is included by comparing Absolute Pressure as well, correct? Hope the above helps |
October 3, 2017, 19:52 |
Rep Power: 143 |
Note that the pressure reported by the CFX solver in buoyant simulations is corrected for the hydrostatic head.
October 5, 2017, 10:01 |
Rep Power: 11 |
October 5, 2017, 10:12 |
Erik
Rep Power: 23 |
Absolute Pressure takes into account gravity head. You will see higher absolute pressure at the bottom of a tank.
Pressure and Total Pressure have this term taken out. The bottom and top of a tank will show the same pressure and total pressure. |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
Total Pressure or Total Pressure in Rel Frame | MissCFD | CFX | 4 | March 24, 2015 04:19 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
