wall at the exit
Old   December 19, 2002, 08:47
Default wall at the exit
Olivier Macchion
Hello people !
My geometry is a diffuser whose section is circular at the inlet and is rectangular at the exit. The angle of the diffuser is large so there is separation.
To model this and keep an Outlet boundary condition at the exit, I have extended the duct by 10 diameters at the exit. But it says that it must add a wall at the outlet to prevent flow to flow in through the outlet. So I added 3 diameters more at the outlet, and I got the same problem after 4 iterarions.
Is there someone who would have another suggestion to solve this problem ?
Thank you very much and happy Christmas everybody !
regards
Olivier
Old   December 19, 2002, 10:23
Default Re: wall at the exit
Holidays
Use the option "opening" or continue as it is as this may be due to the initiation of the flow (you my consider an initial guess); there's a key word to get rid of th walls (it's in the manual) but I would still prefer to use the "opening" boundary...
Old   December 19, 2002, 10:37
Olivier
Thank you !
Happy Christmas !
Olivier
Old   December 19, 2002, 19:53
Neale
Olivier,
The walls are likely fine and this is probably just a "transient" effect, i.e. it will go away. Get a converged solution and see if they still exist. If so, then you might need to switch to an opening.
Neale
Old   December 22, 2002, 14:41
Default Re: wall at the exit - Merry Christmas !
Olivier
Thank you Neale !
I launched a calculation and I will see if it converged as soon as I get back from holidays.
Have nice fests for the New Year !
Olivier
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Tomiyama wall lubrication force Edy OpenFOAM 10 December 13, 2010 11:41
Wall functions tutlhino OpenFOAM Pre-Processing 0 July 2, 2007 05:04
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
