October 4, 2017, 14:49 |
Suction surface separation in Turbogrid
tamer fathy
Hi all I created split surfaces in ANSYS Designmodeler and used the export points feature to create the mesh of a blade in Turbogrid but I can only see the suction surface ( which is included of multiple surfaces I created before) as a one piece and I want to define different surface roughness on separate regions on the SS of the blade, what should I do? Thanks
[ICEM] Surface mesh not sticking to surface | holtwong | ANSYS Meshing & Geometry | 2 | April 20, 2023 08:28 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
killed "snappyHexMesh" | parkh32 | OpenFOAM Pre-Processing | 2 | April 8, 2012 17:12 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
