Vortex Shedding
Old   December 23, 2002, 06:58
Default Vortex Shedding
Dave
Hi, I've been trying to simulate 2D vortex shedding in CFX551 using the new 2D mesher and the SST turbulence model. I've been trying to match a Re number of 140. So Far I have not managed to get anywhere with the simulation. Does anyone have any advice one the modelling of vortex shedding. Also what sort of Timestep should I be using ?? Physical ? and what sort of Time step size ?? Cheers for the help, and have a great christmas and new year Dave
Old   December 24, 2002, 11:44
Default Re: Vortex Shedding
Neale
Dave,
- Re=140 is probably a laminar flow, so turn off the turbulence model.
- Run it transient with a small enough timestep to resolve the shedding frequency you expect
- You might have to perturb the flow to get the shedding going. Numerical diffusion can tend to cause the flow to look stable when it shouldn't be and sometimes you just need a bit of kick to get things going.
- Watch your confinement of the cylinder. I'd say you probably want at least 4 diameters on the cross stream direction.
Neale
Old   December 28, 2002, 14:57
Jan Rusås
Dear Neale, I have had the same kind of problem, In CFX4 I did predict the vortex shedding within 0.1% accuracy. In CFX5 I did not get any transient flow at all. What is the fastest approach to initiate some disturbance? Regards Jan
Old   December 28, 2002, 23:01
xincheng
i have the same problem,would any one solve it,thanks!
Old   December 30, 2002, 16:46
Neale
I have not had much time to play around with this but perhaps a small perturbation on the inlet velocity upstream of the cylinder? Something like 1% of the mean speed or so....
Neale
Old   January 2, 2003, 08:08
Bob
HI Everyone Happy New Year and thanks for the help on the problem. One last question to Neale. You said that you should try and perterb the flow. Could this be achieved by applying a wall roughness to a single side of the cylinder. Just a curiosity really rather than a specific reason for doing it this way rather than the way you suggested. Cheers again Bob
K-Epsilon for Vortex Shedding Sham FLUENT 33 March 29, 2017 05:48
Transiet Animation - vortex shedding derz CFX 5 May 10, 2010 09:21
Vortex shedding, FSI-analysis, turbulence numerics tallknuseren CFX 3 May 10, 2010 04:31
Vortex shedding behind cylider in cross flow Muthu FLUENT 0 March 6, 2006 10:29
basic vortex shedding john Main CFD Forum 4 November 6, 2000 13:23
