Internal wall misdefined as a Domain Default boundary condition |
October 11, 2017, 03:49 |
Rep Power: 8 |
I have generated a mesh (in ICEM) over a 3D region with an internal wall separating it into two bodies. However, once I import the mesh in CFX, I see that the internal wall is not recognised and it automatically named as Default Domain Default with a wall boundary condition on it. I was wondering if anybody has a clue why this happens. Many thanks in advance, Best |
October 11, 2017, 06:14 |
#2 | |
Rep Power: 143 |
October 11, 2017, 06:50 |
Rep Power: 8 |
Thanks for the reply. Not really because this surface (which is now located in Default Domain Default) should be an internal wall through which flow passes freely. But now it is automatically defined as a no-slip wall. Thanks a lot. Best |
October 11, 2017, 10:40 |
Rep Power: 32 |
In ANSYS CFX, there is no such thing as an internal wall.
Meshes do not have physics concepts attached to them. Once the mesh is imported, physics is added to sections of the mesh as you insert boundaries and define their type. Are you referring to mesh faces between two sub-volumes of the mesh? If those faces are not identified as internal mesh faces (for which physics cannot be assigned), you must then insert a domain interface to join both sides of that surface you created in the ICEM to split the volumes. You can then indicate if the interface is a wall, or just flow pass-through boundary (general connection). Hope the above helps, |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 01:54 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
