Unigraphics -> CFX4 Build
Old   February 11, 2003, 06:41
Default Unigraphics -> CFX4 Build
Vincent
I'm trying to import a geometry from Unigraphics (version 18) into CFX Build. First I export a parasolid from UG (test10.xmt_txt), thereby putting the version to 17 (I have read that only files from UG versions 17 and lower can be imported). Then I try to import this file into CFX-build, but get the following error:
'Unigraphics reports error opening file ./test10-ps0001.xmt_txt. Check partfile, path name, version number and run time enviroment variables and/or support files.'
So it look likes UG gives the error. Can it be a problem that UG and CFX4 are not running on the same computer. So I'm modelling in UG on a other computer than where CFX4 is running on. When I export a file from UG I copied it to the other computer. Can anybody help me out,
with thanks in advance, Vincent.
Old   February 11, 2003, 16:04
Default Re: Unigraphics -> CFX4 Build
Hi Vincent,
Try exporting the parasolid from UG as a version 11 parasolid (I think that's right). The cryptic error message from Build is trying to say it can't understand the file as it is a different version.
Glenn
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
BUILD MESH: CFX4 RK CFX 0 June 25, 2005 06:12
CFX4 Build KKA CFX 7 December 10, 2003 01:01
need ICEM CFD HEXA ---> CFX4 example leonard CFX 3 October 18, 2002 07:53
Unigraphics --> Fluent Megan FLUENT 2 October 25, 2000 10:47
